Westinghouse N 202 ?
05-12-2010, 02:10 PM
Post: #1
Can not find anyinfo for this model. The case looks like a model H202 but chasis is not
05-12-2010, 03:35 PM
Post: #2
Re: Westinghouse N 202 ?
Model number what you go by not chassi . There is a schematic @ http://www.nostalgiaair.org for a h202.
05-13-2010, 07:38 PM
Post: #3
let me clear up- the wood case looks like an H202 the back cover says westinghouse N202 and the tubes are not those used in an-H202 and the schematic for the H202 is not even close to what is there.
thanks again |
05-13-2010, 09:07 PM
Post: #4
Ihave 5 other forums searching this . Find out if there is any info.
05-13-2010, 10:34 PM
Post: #5
Is this an American made radio? Reason for asking is that sometimes Canadian made radios have their own numbering system. 'N' is an unusual prefix for a Westinghouse. Is there anything about it that may indicate an export version?
05-13-2010, 11:22 PM
Post: #6
The schmatic for the M102 has the same tube line up ect .
05-14-2010, 02:41 AM
Post: #7
On my search i found out rca victor made some radios for westinghouse. Also some set used social security numbers of owners . I all so found out most set numbers started out with m or w . I registered with a new forum on my adventure a guy had a N202 trying to give away . Said it was set from H**l .
Kent. |
05-14-2010, 01:44 PM
Post: #8
Thanks for the info
05-15-2010, 05:50 PM
Post: #9
the schema for the M102 matches what I have. It is a piece of ####.Wiring is rubber and worse than a 41290 Philco, wire wound resisters checked 4 and all checked bad. Will save for a rainy day
05-15-2010, 06:54 PM
Post: #10
Sorry . did not have any luck . Reason the guy got rid of his same problem you have. Idid find a telephone # of a guy who redid one 1-800 - 595 -0191.
His name is Ben. |
« Next Oldest | Next Newest »
User(s) browsing this thread: 1 Guest(s)
Home
Search
Members
Donate
Rules
Facebook
Help
