Threads: 3
City: Beaverton
State, Province, Country: Oregon
I finished restoring this nice model 16 Tombstone. It has a tone coming through the audio much higher than power supply hum. I would describe it more like an audible note or tone. All Bakelite blocks recapped, New filter caps. There were a few dog bone resistors out of range so I replaced them. The radio plays fine otherwise. Shadow meter works good. Alignment went well. Any ideas would be appreciated. Thanks, Mike.
Threads: 3
City: Beaverton
Fixed it. I started grounding the grids of the 42 output tubes, no change. Then the 42 second audio, no change. Then the grid cap of the 77 first audio no tone noise. I replaced the 77 first audio, problem fixed. No noise, radio plays and sounds great. Thanks to all that looked at this thread. Mike
Threads: 530
City: Jackson, NJ
It is also possible the 77's grid cap wire was outside of the shield and not inside, and while replacing the tube you put it back inside.
