As most of you know, I invested in a Siglent SDG1032X function generator a few years ago after using an old Clough-Brengle for decades, then a B+K 4040 like John B's for a while.
Pros of the Siglent: Direct digital readout, no drifting.
Con of the Siglent: Output level too high for typical vintage radios, must be reduced to a usable level with the use of inline BNC attenuators. I am using three such attenuators, a 20 dB, another 20 dB, and a 14 dB to reduce the output signal by 54 dB. This has solved my "signal too strong" issue.
While I liked my B+K 4040, I did not like the fact that it, too, drifted in frequency while in use. Of course, the old 1930s Clough-Brengle drifted badly.
With the setup I have now, I am able to give my radios the best alignments possible. I recently had my RCA C15-3 console chassis out for a tuneup. The IF alignment was good already, but I was able to improve the RF alignment a good deal.
I'll ask this question - do the HP generators produce a low level signal usable in vintage receivers without overloading them?
Threads: 551
The sole problem with mine is, it is about 50 lbs or so, and moving it to the table and back poses the risk of back problems.
Threads: 88
City: Tacoma
Ron,
The HP generators I had to leave behind would easily go below the thresholds of any radio I worked on (-134dB?)
Threads: 8
City: Roanoke
morzh Wrote:The sole problem with mine is, it is about 50 lbs or so
50 lbs? That's a lightweight. My General Radio Type 805-C Standard Signal Generator weighs 117-1/2 lbs. I like to joke that if a tornado takes my house the workbench will still be there because of the 805-C holding it down.
Threads: 8
City: Roanoke
Ron Ramirez Wrote:I am using three such attenuators, a 20 dB, another 20 dB, and a 14 dB to reduce the output signal by 54 dB.
Ron - The HP 355C (0-12dB in 1 dB steps) and 355D (0 to 120dB in 10dB steps) step attenuators are more elegant solutions. I have long owned both, largely for use with GR unit oscillators which lack step attenuators.
Ron Ramirez Wrote:... do the HP generators produce a low level signal usable in vintage receivers without overloading them?
They do - around less than 0.1 microvolt into 50 ohms is not unusual.
Jackson 715 not working
Now that you posted the schematic, I don't know why that Sprague electrolytic cap is across the meter, as it is not indi...MrFixr55 — 05:51 PM |
What may be lacking in the PP Tube amps may be the 2nd harmonics, which some, especially RCA back in the day called &quo...MrFixr55 — 05:32 PM |
Usually in an emission tester, the tube under test is measured as if it were a diode. So, some testers connect all the g...RodB — 04:17 PM |
Restoring Philco 37-604C
Yep. F5 is green, D5 is Red.
Red is Bad.
Green is Clean.morzh — 01:30 PM |
I did start to do that but I stalled out because I could not figure out how the grid and plate get voltage. In this diag...daveone23 — 11:52 AM |
(Insert Homer Simpson "DOPF" Here.)
When all fails, look at the can. Took the Ron Ramirez advice, red Caig D...MrFixr55 — 09:23 AM |
Philco 91 Speaker Replacement
From your text I am not sure if you intend to use the existing speaker with a resistor instead of the field coil.
It wo...morzh — 08:44 AM |
My field coil is bad. I am still hoping to find an original, but if I can't I will go with a fitting Philco speaker, 125...dconant — 08:34 AM |
As Rod said, it is OK to use a fitting speaker, and then look for an original one.
If you buy a Hammond 125 output tr...morzh — 08:15 AM |
Yes, I often have to substitute, then keep an eye out for an original. In the meantime, the radio is working and being e...RodB — 08:02 AM |
