Philco All-Purpose Set Tester Model 048A
Group: Some of you may have seen the pristine 1936-ish model 048A All Purpose Set Tester on ebay recently. I was the winner of that auction and probably paid too much, but I couldn't resist.
This unit looks like it was used briefly when it was new and then was tucked away for 85+ years and then found in an attic when a house was being cleaned out. Anyhow, the wooden cabinet is in excellent shape with the original handle looking like new and the Philco logo on front being unblemished.
It included all of the probes that originally came with it - and the hang tags that attached to the switches when it was new (Nathan S. I will scan those for inclusion in the library) and the best of all - all 3 of the original Philco P-155 "C" batteries (22.5 V each) still in place. They are awesome - the tar in the top has the voltages stamped in them. The 1.5V "flashlight battery for the ohmmeter is a 1930s Burgess uni-cell replacement with a 1933 patent date so it too has been there a long time. No mods have been done to this one and it is as original as they come. so many of them were converted to using battery eliminators - this was the first one I have seen that was not modified. If there is every a Philco museum, this one should be in it. -- Andy
Andy Sorrell
Palmyra, Virginia
Andy, that's a beauty, congratulations Icon_thumbup
Very nice!
Icon_thumbup
hello Andy,
That is a great find and anyone who is a true Philco or test equpment collector would enjoy it .
Jackson 715 not working
Mrfixr55, its working now. I cleaned the switches and sockets with spray cleaner. Thanks for helping on this one.daveone23 — 06:26 PM
Now that you posted the schematic, I don't know why that Sprague electrolytic cap is across the meter, as it is not indi...MrFixr55 — 05:51 PM
What may be lacking in the PP Tube amps may be the 2nd harmonics, which some, especially RCA back in the day called &quo...MrFixr55 — 05:32 PM
Usually in an emission tester, the tube under test is measured as if it were a diode. So, some testers connect all the g...RodB — 04:17 PM
Restoring Philco 37-604C
Yep. F5 is green, D5 is Red. Red is Bad. Green is Clean.morzh — 01:30 PM
I did start to do that but I stalled out because I could not figure out how the grid and plate get voltage. In this diag...daveone23 — 11:52 AM
(Insert Homer Simpson "DOPF" Here.) When all fails, look at the can. Took the Ron Ramirez advice, red Caig D...MrFixr55 — 09:23 AM
Philco 91 Speaker Replacement
From your text I am not sure if you intend to use the existing speaker with a resistor instead of the field coil. It wo...morzh — 08:44 AM
My field coil is bad. I am still hoping to find an original, but if I can't I will go with a fitting Philco speaker, 125...dconant — 08:34 AM
As Rod said, it is OK to use a fitting speaker, and then look for an original one. If you buy a Hammond 125 output tr...morzh — 08:15 AM
