Philco 066 Tube Tester 1937-38 Tube Chart
Group:
There does not appear to be much data out there on this model. The 1944 Philco test equipment manual shared by Dale Cook includes a schematic of it but no parts list and I don't know of an operations manual. Attached are copies of the Tube Chart that comes with the tester including an update from a 1938 Philco Serviceman. If anyone has a parts list and/or a operations manual I would love to see them! -- Andy
Update 12-13-23: I noticed I left off a page in the tube chart. So the revised attached pdf adds that. I also added all the info I could find in the Philco Servicemen newsletters I have. Model 066 does not seem to have been Philco's state-of-the-art for long - 066 was release in mid-1937 and by the summer of 1938 this model 033 was released and was being heavily promoted by Philco. A neat thing i did notice in model 066 - is uses a shadow meter for its line test!
Andy Sorrell
Palmyra, Virginia
Great addition Andy! Thank You.
Jackson 715 not working
Now that you posted the schematic, I don't know why that Sprague electrolytic cap is across the meter, as it is not indi...MrFixr55 — 05:51 PM
What may be lacking in the PP Tube amps may be the 2nd harmonics, which some, especially RCA back in the day called &quo...MrFixr55 — 05:32 PM
Usually in an emission tester, the tube under test is measured as if it were a diode. So, some testers connect all the g...RodB — 04:17 PM
Restoring Philco 37-604C
Yep. F5 is green, D5 is Red. Red is Bad. Green is Clean.morzh — 01:30 PM
I did start to do that but I stalled out because I could not figure out how the grid and plate get voltage. In this diag...daveone23 — 11:52 AM
(Insert Homer Simpson "DOPF" Here.) When all fails, look at the can. Took the Ron Ramirez advice, red Caig D...MrFixr55 — 09:23 AM
Philco 91 Speaker Replacement
From your text I am not sure if you intend to use the existing speaker with a resistor instead of the field coil. It wo...morzh — 08:44 AM
My field coil is bad. I am still hoping to find an original, but if I can't I will go with a fitting Philco speaker, 125...dconant — 08:34 AM
As Rod said, it is OK to use a fitting speaker, and then look for an original one. If you buy a Hammond 125 output tr...morzh — 08:15 AM
Yes, I often have to substitute, then keep an eye out for an original. In the meantime, the radio is working and being e...RodB — 08:02 AM
There are currently 5130 online users. [Complete List]
» 1 Member(s) | 5129 Guest(s)
