philco antenna coils etc u henny ety for each coil
looking for actual values of philco antenna coils etc u henny ety for each coil
it shows part number but the part number has no actual value
dont have orginal to count turns etc .. i CAN  bulld a coil if i knew the value i need. and one know of such a parts list showing value \of each coil by part number
So why don't we start off with what model number set you are servicing? And what coil or winding is failed?
There is no factory list of coil inductance vs p/n. Sometimes guys that are rewinding a coil will note the number of turns and ga of wire so other  can do the same job w/o counting and such. It can be found in the library but mostly for very common sets.
GL
