Is there an AC version similar to a 37-624?
12-28-2010, 06:11 PM
Post: #1
Does anyone know if there is an AC version of the 37-624, a 6-tube 6-volt DC farm set? It has a complex 3 section bandswitch, and a very high build quality. I restored a 37-624 - one of my favorite restorations (and very complex). Here is the after restoration photo, in case someone recalls a similar AC set:
![]() Thanks! |
12-28-2010, 06:14 PM
Post: #2
Re: Is there an AC version similar to a 37-624?
Yes - Model 37-620.
http://www.philcoradio.com/gallery/1937a.htm#ab Congrats on the restore. Did you restuff the paper caps? -- Ron Ramirez Ferdinand, IN |
12-28-2010, 07:49 PM
Post: #3
Ron Ramirez Wrote:Yes - Model 37-620. Yes, all capacitors were restuffed. The radio was all original when received. I always try and retain all originality possible. I have the time! And it's a hobby, not a business. Here's my restoration log for that radio. http://mcclellans.com/Philco%2037-624%20Restoration.htm |
01-05-2011, 03:25 AM
Post: #4
I've been told I was crazy to dig out the tar on the old "speed boats" and put new caps & resistors inside vs. clipping leads and doing the replacement externally. But you are the first I've known to "re-stuff" the small capacitors. I'd like to start doing that. Could you explain the process, please? Thanks, David
01-05-2011, 04:41 AM
Post: #5
David
An excellent tutorial on this subject may be found here, on Chuck's site: http://www.philcorepairbench.com/capbuild.htm -- Ron Ramirez Ferdinand, IN |
01-05-2011, 11:57 AM
Post: #6
I think David is asking about the paper tubular caps. Once removed use a heat gun to heat the wax. Hold on to it with a rag grab one of the leads with pliers and pull. the innards will slide out leaving just the paper tube. I just slip the replacement cap inside without sealing up the ends. Some guys will use hot glue over the ends of the tube.
Terry |
01-05-2011, 02:16 PM
Post: #7
I re-stuffed the paper caps on one radio I restored by using my drill press to drill out the innards from one end and after putting the new smaller part inside, I hot waxed the open end. Then I re-dipped each cap in melted wax that I got from a craft store so they looked original. That was a lot of work and I'll not do it again.
Steve D |
01-05-2011, 02:30 PM
Post: #8
Steve D Wrote:Then I re-dipped each cap in melted wax that I got from a craft store so they looked original. Steve D What type of wax did you use? I tried once to dip restuffed caps in paraffin from a melted candle, but that did not work too well. Did you use beeswax? I normally clean off the existing wax on the outside of the caps before restuffing, since in most cases it is very dirty and grungy. I heat it up using a small alcohol lamp or heat gun and wipe it off using paper towels. |
01-06-2011, 02:28 PM
Post: #9
Yeah, I also heated most of the old wax off ans then cleaned the paper tube lightly with lacquer thinner before dipping in new wax. I got a beeswax formulation form Michael's craft store. It comes in a block that appears opaque white but when melted becomes clear. I have attached a photo of the chassis underside while I was working on it.
Steve D Note from site admin: Sorry, but the photo which was attached to this post is no longer available. |
« Next Oldest | Next Newest »
User(s) browsing this thread: 1 Guest(s)
Home
Search
Members
Donate
Rules
Facebook
Help
![[Image: AfterChassis-1.jpg]](http://mcclellans.com/images/Philco37-624/AfterChassis-1.jpg)
