Post Reply
  • 0 Votes - 0 Average
dial string
06-27-2011, 01:54 PM
Post: #1
dial string
Just another idea on what to use for dial string. I recently found out that builders string works perfectly. This string is used by builders, with a bubble gauge, to insure walls are level and true. It's less than $3.00 a roll and what you have left over, can be used for lots of other projects around the house. I found that if you put a small piece of masking tape on the ends it makes it much easier to work with. Remove the tape after tying your knots.
Find all posts by this user
06-28-2011, 01:26 PM
Post: #2
Re: dial string
Hi,
Thanks for the tip - is builders string made of nylon, or ???
Ferdinand, IN
Visit this user's website Find all posts by this user
Post Reply
Forum Jump:
