Finally (!) Some Progress Restoring the Cabinet of my 41-280
Good day, all...
Well, I finally have made enough progress on my restoration project (Philco 41-280) that it no longer looks as if I've just been sitting on my hands for the past couple of weeks!
As I began this project, it became apparent to me that the preferred method of transporting this old radio must have been 'rolling it end-over-end down a gravel road!' While still solid, it was pretty banged up; only a couple of really nasty chips to the solid wood (and both of those - thankfully- on the very bottom). But there were countless little bumps and bruises. There was one pretty bad veneer chip in the left top [horizontal] panel, and rear of both of the curved side panels had severe veneer damage.
So, being new to all this, I took the radio cabinet completely apart... pretty courageous (or absolutely nutz!) for a genuine newbie. Of course, as soon as the curved panels were free from their seventy year captivity, they started "relaxing"... trying to straighten back out (as you can guess, this made reassembly a bit of a challenge.
Anyway, I removed all the veneer from the damaged panels and re-veneered. I had to make a holding fixture for the curved panels so that I could really "bear down" during the process (I used old-style contact cement).
I used acetone to remove the old lacquer and hand sanded the solid wood parts to remove all the little bumps and bruises (and there were a bunch of those!). I restained everything with General Finishes "Brown Mahogany" gel stain (I don't know why they call it that, it's all brown and no mahogany!).
I agonized over what to do about the totally useless photo finish on the vertical pieces that flank the speaker opening. After weighing all the options, I wound up taking the easy way out... I just stained them with Bartlett's "Jet Mahogany" gel stain (four applications) to get an acceptable contrast.
The fnal finish was with DEFT [spray can] lacquer. This is the first time I have ever used this product, and I really like it!
So, that's where I am... This project will be a disappointment to the experienced and certainly to those who highly prize originality (and, be assured, I deeply admire both of those groups!), but it is turning out OK for my first try... and better than that, my wife loves it!
More later... I hope.
Rob
[Image: http://i5.photobucket.com/albums/y173/z-...C_5731.jpg]
[Image: http://i5.photobucket.com/albums/y173/z-...C_5730.jpg]
[Image: http://i5.photobucket.com/albums/y173/z-...C_5729.jpg]
[Image: http://i5.photobucket.com/albums/y173/z-...C_5728.jpg]
Looks great!
Nice shine
The good thing is you used laquer so you can go back and use either Mohawk or Deft shading laquer if something looks a little too light, something you may want to consider around the top edge and the other cheap wood parts that don't want to accept stain. That faux graining near the grille can be replaced with 3M Dynoc or by painting but looks fine darkend up. If you had used polyurethane (YUCK!) on the cabinet you couldn't do anthing to it other then paint it or strip it.
Arran Wrote:The good thing is you used laquer so you can go back and use either Mohawk or Deft shading laquer if something looks a little too light, something you may want to consider around the top edge and the other cheap wood parts that don't want to accept stain.
Actually, I'm quite happy with the 'color' and overall uniformity provided by the gel stains. Of course, the nature of gel stains is that it not only 'goes into the wood,' it also 'builds up' on the surface. That makes it most useful for this kind of work... the color and the 'depth' of the hue is easily controlled by using multiple applications ('coats').
Arran Wrote:That faux graining near the grille can be replaced with 3M Dynoc or by painting but looks fine darkend up. If you had used polyurethane (YUCK!) on the cabinet you couldn't do anthing to it other then paint it or strip it.
I assume that you are speaking about the flat panel that goes into the opening just under the 'top'... where the ' PHILCO ' decal goes. My plans for that piece is to use interesting book-matched veneer, stained to blend with those plain-but-darkened vertical pieces.
Rob
This radio looks great. I too have a phiclo 41-280 just like yours that I am restoring. What species of veneer did you use for the radio. Also do you know of anywhere to repair or get a chassis for this model of radio.
Just excellent Icon_biggrin
Ash
jsa-294 Wrote:This radio looks great. I too have a phiclo 41-280 just like yours that I am restoring. What species of veneer did you use for the radio. Also do you know of anywhere to repair or get a chassis for this model of radio.
Good evening!
Thanks for the kind words!
I used mahogany veneer that I bought at my local Woodcraft store. I hand selected the veneer for a close match in grain structure more than trying to match color... heck, with the magic of modern gel stains, I can make it about any color I wish.
For more, you might find it useful to review this thread: http://philcoradio.com/phorum/showthread.php?tid=4047 In it, I discuss the completion of this little project.
The guy who did the restoration is Randal Walls at Texas Vintage Audio http://www.texasvintageaudio.com/index.html
Cheers!
Rob
that looks beautiful bet you cant wait to sit back and play some music light up a cigar or crack open a pepsi which ever you prefer
Wow, very nice! The photo finish makes it tough to restore, I like how you addressed that.
I like stain too. But often with these old sets it is difficult to get it to absorb evenly. For darker colors lacquer toner is definitely better.
Correct model 84 Ac plug an cord type
From what I read Philco went to using brown rubber power cords in 1936, so cloth was used in the 1935 and earlier models...Arran — 11:25 PM
Hi Bruce, I have not worked on an 84, but in general, power cords for almost any radio prior to 1938 was cloth covered...MrFixr55 — 08:34 PM
Restoring Philco 38-14
OK, well, so after staring at the sch again, I realized the problem had to be the #12/12A padder. I put a scope on the o...morzh — 08:15 PM
Hello Bruce, I mostly use brown far as my cloth powercords go ! Here is the plug that I have used bakelite Acorn style...radiorich — 08:05 PM
Looking for as correct as can find the right Ac plug an the correct colored cloth line. Ive seen many old photos but mos...Bruce — 04:13 PM
Rod Two Y-caps make sense if you use them from L/N to the chassis; this is only makes sense in the transformer radios...morzh — 10:11 AM
Mike, I'm curious about a specific use of he Y cap. Lately I've seen a single cap across the power transformer primary. ...RodB — 09:01 AM
hello morzh , That sounds like a plan ! Sincerely Richardradiorich — 07:45 AM
Richard, It helped some, but I still had the whining when engaging the rear power strip (I did not realize it was fro...morzh — 07:07 AM
Hello morzh, Yes , that dreaded hum in my room where i do alighment I have my cable modem and router plus desktop plus ...radiorich — 11:25 PM
