Phorum How-To #6: How Can I Add or Change an Avatar?
An avatar is a small picture you would like to be associated with yourself on the Phorum. It can be a picture of you, of a favorite radio, or just about anything else that is in good taste, not indecent, and that does not violate Phorum rules.
To add an avatar, just go to your User CP:
[Image: https://philcoradio.com/images/phorum/Ph...06_001.jpg]
Look in the Menu column at left for the Change Avatar link.
Click or tap the Change Avatar link under Your Profile.
This takes you to another page:
[Image: https://philcoradio.com/images/phorum/Ph...06_002.jpg]
Look in the Custom Avatar section of this page.
[Image: https://philcoradio.com/images/phorum/Ph...06_003.jpg]
Where you see Upload Avatar, click or tap the Choose File button. This opens a window which allows you to choose a suitable avatar from your computer. Click or tap the avatar you wish to use, then click or tap the OK button. That window will now close. The filename of your avatar will then appear to the right of the Choose File button.
Important Notice: Your avatar must not be larger than 100 x 100 pixels, and cannot be larger than 9 KB in size. If it exceeds these size limits, it will not work.
Once you find the avatar you wish to use, click (tap) the Change Avatar button and then your new avatar will appear next to your username in all of your Phorum posts.
If you have an avatar on Gravatar, you may enter the email address you use for your Gravatar account into the appropriate box and then click or tap the Change Avatar button.
Atwater-Kent 84, restoration.
That one cannot be taken apart well. It is riveted. But the domed switch luckily has some spacing (not much and not inte...morzh — 09:44 PM
Hello Mike, that D5 is great for switches and I do the same I will try spraying it through a side hole first before tak...radiorich — 09:38 PM
Almost decided ot turn it on, but didn't like the power switch being 50 - 100 Ohms, so it is the same exact switch as in...morzh — 08:56 PM
Philco 49-1040
+1 Bob. Yeah, they bought it in 1949 or so, but by 1960, with the CRT starting to dim and after having the set repaired...MrFixr55 — 04:41 PM
Hi Richard. Yes, we are waiting for warm weather. I have more than a dozen hulls waiting to be painted.RadioSvit — 11:06 AM
6TPZ and 5TPO Radio Help
Then it is even easier. Yep, my GE guide also says "Silicon".morzh — 09:43 AM
462ron
Mike, according to my ECG replacement guide, the AR107 & AR108 both cross reference to a ECG 123A as does a GE-10. T...462ron — 09:41 AM
The 66 Ohm filter in the 1st detector's plate circuit. Look in the early version sch. Here it is, the spiral that ma...morzh — 09:11 AM
Ron yes, that was found. The problem is trying to find GE-10 for AR107/108. I could not find even mentioning of it. ...morzh — 09:06 AM
462ron
Your output transistor X6 cross references to a GE-3 transistor and I’ve used that before. There are a few here on eBay…...462ron — 07:58 AM
There are currently 3775 online users. [Complete List]
» 1 Member(s) | 3774 Guest(s)
