Phorum How-To #10: Forum Display Options
Go to your User CP, then click or tap the Edit Options link.
[Image: https://philcoradio.com/images/phorum/Ph...10_001.jpg]
In this lesson, we are going to examine the Forum Display Options box (upper right).
You can choose how many threads should be displayed in a forum (the default is 50 threads) by clicking or tapping the drop-down box under "Threads Per Page:"
[Image: https://philcoradio.com/images/phorum/Ph...10_002.jpg]
If 50 is too many for you, choose a lower number of threads from the drop-down box.
Now let's take a look at "Default Thread View."
This tells you how many older threads you want to be able to see. You can set the Phorum to display as few as the threads from only the last day, up to every thread in the Phorum database.
The default here is Show all threads. It is strongly suggested that you leave this at the default setting. If, for some reason, you do not wish to see older threads, however, you may change this by clicking or tapping the drop-down box under "Default Thread View:"
[Image: https://philcoradio.com/images/phorum/Ph...10_003.jpg]
When finished, don't forget to click or tap the Update Options button at the bottom or else your changes will not be saved.
Jackson 715 not working
Now that you posted the schematic, I don't know why that Sprague electrolytic cap is across the meter, as it is not indi...MrFixr55 — 05:51 PM
What may be lacking in the PP Tube amps may be the 2nd harmonics, which some, especially RCA back in the day called &quo...MrFixr55 — 05:32 PM
Usually in an emission tester, the tube under test is measured as if it were a diode. So, some testers connect all the g...RodB — 04:17 PM
Restoring Philco 37-604C
Yep. F5 is green, D5 is Red. Red is Bad. Green is Clean.morzh — 01:30 PM
I did start to do that but I stalled out because I could not figure out how the grid and plate get voltage. In this diag...daveone23 — 11:52 AM
(Insert Homer Simpson "DOPF" Here.) When all fails, look at the can. Took the Ron Ramirez advice, red Caig D...MrFixr55 — 09:23 AM
Philco 91 Speaker Replacement
From your text I am not sure if you intend to use the existing speaker with a resistor instead of the field coil. It wo...morzh — 08:44 AM
My field coil is bad. I am still hoping to find an original, but if I can't I will go with a fitting Philco speaker, 125...dconant — 08:34 AM
As Rod said, it is OK to use a fitting speaker, and then look for an original one. If you buy a Hammond 125 output tr...morzh — 08:15 AM
Yes, I often have to substitute, then keep an eye out for an original. In the meantime, the radio is working and being e...RodB — 08:02 AM
There are currently 4632 online users. [Complete List]
» 1 Member(s) | 4631 Guest(s)
