Escutcheon re-plating
Hi-
Who do you recommend for metal escutcheon re-plating?
Lew
what model radio? Hard to recommend something if we dont know what your talking about. Chrome Scott dial, antique brass, chemically treated??
Lew
If it is one of the early escutcheons that someone has polished to bright brass and you're wanting to restore the "patina," I suggest a light coating of Van Dyke Brown toning lacquer. After spraying, you can rub out the high spots if you wish, for a very neat appearance.
If it is a 1940 steel escutcheon that was plated brass, light coats of antique brass spray paint (available in hardware stores) will make it look like new.
Heres another option.......
This bezel was painted (by a previous owner, not at the factory). I stripped the paint, then a good cleaning with muratic acid, wash with water, dry, then I used some "gun blueing" from Wallmart (sporting section). Dont worry, it turns it black, not blue. Just another option.
[Image: http://i9.photobucket.com/albums/a77/1ph...nit020.jpg]
Jerry - great point, and nice job! I'd forgotten about the gun blueing. I know a fellow who collects radios and Aladdin lamps, he restored the bronze look to an Aladdin Model 12 using the gun blueing method.
Philco 39-116 radio and remote
The transformer I located is from a Philco TV chassis, circa 1948. The part number is 32-8391 I do have the replace...Brad Winder — 08:59 PM
Philco 41-221 Restored
Hello Rod, Wow that radio looks great nice job ! Sincerely Richardradiorich — 07:39 PM
Philco 269 - 444 FIVE VALVE VERSION?
From what I can remember the model 444 "People's Radio" used a special tube/valve called a PenDD61, it was the...Arran — 06:54 PM
Nice Radioslford310 — 06:24 PM
Hi Chaz,  You may want to post the tubes used in your radio.   From Radio Museum, it seems that the set uses some ...MrFixr55 — 05:14 PM
Today my grandson and I finished the restoration of this Philco 41-221. It has had all the rubber coated wiring replaced...RodB — 03:19 PM
Hi Brad, I had no idea that the overheating was problematic in this radio.  Do you know the part number of the transfor...RichG — 03:01 PM
From the photo it looks the sockets are screwed and the front one does not even match the hole.morzh — 02:54 PM
Hi Chas a welcome, Perhaps we'll have to reverse engineer this to sort it. So let's start w/what tubes does it use? And...Radioroslyn — 12:28 PM
Hi Rich, From my experience, unfortunately it is not uncommon to find the power transformer in the 39-116 to be overhea...Brad Winder — 09:25 AM
