80 Jr. Volume regulator
Well, I gave it a shot.
I opened it up, cleaned it (with alcohol - Varsol seems to be not readily available), used some DeoxIT Greenlabel (Fader Lube) on it.
Where it was the low volume sector, there was bad-bad-bad scratching and the volume would go up (I figured - bald spot), so after cleaning this remained unchanged. I can't have low volume on this thing. After opening, the element did show a large etched bald spot, so obviously through some weird pattern the wiper connects back to a higher resistance part of the scale, increasing the volume, and then, after some really bad scratchy zone, goes almost to zero.
Don't think much can be done.
So, anyone know off hand a replacement part that would mechanically be a good fit? It's a 20K potmeter (don't know linear or logarithmic), with SPST rotary switch.
I looked in Mouser, doesn't look like they have what would fit.
You do have a good ground on the radio, right? My jr does the same thing if the ground wire isn't hooked up.
John
Las Vegas, NV USA
Do you mean if I have the Chassis actually connected to the Earth GND, or do you mean a good connection of the Volume pot to the GND?
The latter I do.
The former I don't.
But the same exact principle (the pot dividing Antenna directly) applies across many Philcos, in my 20 in particular, and it works just fine, and I don't see why not. The divider is there.
Just hooked the GND wire to GND in my outlet. Same thing, nothing's changed.
Well, I just paid a bit more attention. With or without GND connected there is a change in volume.
The problem is that where it would be an acceptable volume level while listening to the loudest station, this is where that bald spot is.
So the volume stays very loud, and then goes to almost nothing. But it does change.
I have to tune out a bit, and thus make the station less loud, and then the volume regulation works better.
But...still a new regulator would be better.
Two thoughts come to mind. Try rubbing some pencil lead in the bad area of the control. This may restore the resistive path around the control. Or wire it backwards. As soon as you turn it on turn it all the way up and then turn in down to increase the volume. Works but is a little counter intuitive.
Terry,
The last suggestion (wire backwards) was my knee-jerk reaction.
Two cons: 1) the way pot is soldered to the chassis is through a riveted GND contact; wiring backward will be awkward. 2) Exactly what you said - counter-intuitive. Icon_smile
As for rubbing a pencil lead, it is an old technique of fixing potmeters, which I used in my young years (long time ago), but it did not last long enough. If there only were some simple process of graphite application the way they do it at the factory. How do they do it? So it actually bonds?
Philco 46-480 Cabinet Restoration
I have since gotten the cabinet stained and toned. I saw a video online of another guy renovating a 46-480, and he used ...jrblasde — 07:37 PM
Philco 39-116 radio and remote
Hi Brad, Thanks so much for the info!  Do you happen to have the specs for the PT-86 transformer?  I did not find a lis...RichG — 04:32 PM
Philco 269 - 444 FIVE VALVE VERSION?
Thanks Arran; If your set has five tubes/valves then it could be an A537, V537, or a U527, then again it looks like s...ChasL0001 — 11:07 AM
Philco 29 or 45
29 chassis has a shadow meter while 45 chassis does not. Shadow meter is part no. 27 in the 29 schematic. compare it t...klondike98 — 10:32 AM
Sorry, Chas. Re the burns, I broke my first TV at the age of 3.  Between my electrical experiments :yikes: (My mom wa...MrFixr55 — 09:07 AM
Philco 41-221 Restored
Thanks for the compliment Richard. The tenite grille is original. A few of the horizontal slats were slightly warped so ...RodB — 08:44 AM
Philco 29 or 45
Hello, I have just received a Philco lowboy where the tube layout label in the cabinet says 29 or 45. There is no label ...dconant — 08:29 AM
Mr fixr, That is great news I would love to see repo grille !! I too have a very similar Philco but my cabinet has fab...radiorich — 08:22 AM
Hi Rod, I always tell people that my scars give me character.  :wink:   Great job on the radio.  Is the grille origi...MrFixr55 — 08:00 AM
It looks like the PENDD61 valve/tube must have failed, so someone replaced it with the EBC33, which is a double diode-tr...Arran — 04:29 AM
There are currently 1889 online users. [Complete List]
» 3 Member(s) | 1886 Guest(s)
