Post Reply
  • 0 Votes - 0 Average
My 39-45 bandswitch had been neutered
04-29-2012, 09:44 PM
Post: #1
Literally neutered. Icon_eek Both balls that provide the detent action are gone. The part that they go on to is still there. Anybody know what I can use for a replacement?
Odd set, almost all of the rubber wiring is in very good shape. I had to replace the 2 wires to the pilot lamp and rebuild its base and one of the dial lamps base (the other had been replaced). replaced 2 of the 3 filter caps that had been changed in the 60's and 2 .01 papers as I was working in that spot. ( and yes I will change the others) but the thing is playing like new.
John
Las Vegas, NV USA
Find all posts by this user
04-29-2012, 10:34 PM
Post: #2
RE: My 39-45 bandswitch had been neutered
I don't know how the switch looks, but in many switches using spring-and-ball detention, those balls are usually the same as those in some ball bearings, so if this is it, then you could get a ball bearing, get balls from there, and get your switch all...ballsy again.
04-30-2012, 12:52 AM
Post: #3
A junker bandswitch from any radio, of the same general size switch, regardless of contact/wafer arrangement should provide the detent balls.
Browse your local swapmeets...
Chuck
Chuck Schwark,
The Philco Repair Bench
[Image: philog3tiny.gif]
http://www.philcorepairbench.com
Visit this user's website Find all posts by this user
Post Reply
Forum Jump:
User(s) browsing this thread: 1 Guest(s)
