rubber tuner supports for 38-116
Rubber tuner supports for 38-116 witch ones to use GPH-690-RF or GPH-RF neither one seems right these are from Renovated radios?
I would use the GPH-690-RF. The RF units in the 38-116 and the 38-690 are the same size, so should use the same mounting grommets.
Thanks Ron
they seemed a little to wide for the pin they go on. that's what I was and am going to order.
Thanks
Vinzer
