Dropping Resistor Tech Sheet
Hopefully this is the correct Phorum for this, if not feel free to move it. Thanks.
[Image: http://i1185.photobucket.com/albums/z345...hsheet.jpg]
Gene
Tnx for the info but they say to install the dropping resistor in to the CT of the HV winding to ground. Don't know that I like that idea so much is it will raise the negative bias volt with keep the plate voltage the same.
