philco 37-650 dial window and surround
trying to remove dial window and surround complete from 37-650 anyone removed this. i dont see anything but two tabs on the back and straightening them didnt help-------------- thanks
Turn the outer ring counter-clock wise and it will come apart. Be careful as the glass will fall out when you do this.
thanks. i will watch the glass
I'm going to try this on a 38-10F. It sounds like it's of simular construction. Thanks.
Yes, same thing. Good luck!
