16B update
I got my parts chassis for my 16B today. Tonight, I swapped out the LO coil for the high bands, and replaced the 700pf cap from the LO plate to the coil. This makes the last cap in the LO circuit. I also got in my 10K WW pot to replace the interstation noise pot.
Good news: all but the highest band are working extremely well. It will need a tiny bit of retweaking to bring the dial back into alignment. No biggie there.
Bad news: Band 5 is still not working properly. In fact, it now dies out at everything below 14 MHz. No matter what I do, I just can't get that bottom of band 5. Icon_sad I've tried grounding the tuner rotor at various points, to no avail.
Anyone got any more suggestions what to try?
TIA
Philco 46-480 Cabinet Restoration
I have since gotten the cabinet stained and toned. I saw a video online of another guy renovating a 46-480, and he used ...jrblasde — 07:37 PM
Philco 39-116 radio and remote
Hi Brad, Thanks so much for the info!  Do you happen to have the specs for the PT-86 transformer?  I did not find a lis...RichG — 04:32 PM
Philco 269 - 444 FIVE VALVE VERSION?
Thanks Arran; If your set has five tubes/valves then it could be an A537, V537, or a U527, then again it looks like s...ChasL0001 — 11:07 AM
Philco 29 or 45
29 chassis has a shadow meter while 45 chassis does not. Shadow meter is part no. 27 in the 29 schematic. compare it t...klondike98 — 10:32 AM
Sorry, Chas. Re the burns, I broke my first TV at the age of 3.  Between my electrical experiments :yikes: (My mom wa...MrFixr55 — 09:07 AM
Philco 41-221 Restored
Thanks for the compliment Richard. The tenite grille is original. A few of the horizontal slats were slightly warped so ...RodB — 08:44 AM
Philco 29 or 45
Hello, I have just received a Philco lowboy where the tube layout label in the cabinet says 29 or 45. There is no label ...dconant — 08:29 AM
Mr fixr, That is great news I would love to see repo grille !! I too have a very similar Philco but my cabinet has fab...radiorich — 08:22 AM
Hi Rod, I always tell people that my scars give me character.  :wink:   Great job on the radio.  Is the grille origi...MrFixr55 — 08:00 AM
It looks like the PENDD61 valve/tube must have failed, so someone replaced it with the EBC33, which is a double diode-tr...Arran — 04:29 AM
There are currently 1996 online users. [Complete List]
» 2 Member(s) | 1994 Guest(s)
