37-630 trim
hello all, i am in the process of refinishing a 37-630 cabinet. my problem is in locating a piece of 1/16 x 3/4" walnut trim to replace a missing side section. the only close replacement i have come across is a roll of veneer striping which would have to be doubled up to match the original thickness. does anyone have a better source they can recommend? thanks, roger
I don't have the original wood but I already have the modern self-stick walnut veneer. You are welcome to a piece of it if you like.
Pete AI2V
