Threads: 7
City: Grand Marais, MN 55604
I have wondered on this for a while... I'm always leery to use anything that would be used on plastic materials on bakelite because, as I understand it the chemical make-up is significantly different. So have stuck to water and soap with a toothbrush.
Would like something to bring them to little bit of a gloss if possible.
What has anyone else used or done to them?
thanks.
Threads: 111
City: Lake in the Hills, IL
I have had great results with Novus #2 or #3 depending on how dull they are. I have never damaged a knob this way.
Eric
(This post was last modified: 01-04-2014, 07:26 PM by
Eric Adams.)
Threads: 267
City: Bandon
State, Province, Country: OR
Here's an earlier thread on the same topic you might find interesting:
http://philcoradio.com/phorum/showthread...+polishing
Threads: 42
City: Ironton Ohio
I first clean them with purple power (best cleaner I have ever used) then I buff with cheap walmart rubbing compound and a dremel "cloth" cleaning wheel not the fiber wheels. They look like they are coated with wet oil after washing the dry compound off. This also works for scuffed/scratched and yellow plastic dial glass. Todd
Threads: 11
City: Ithaca NY
I came across this youtube video a while ago on
bakelite knobs.
I have not tried his technique myself but he claims it works very well
It is in two parts, here's the first part:
https://www.youtube.com/watch?v=UDeE48dVyTw
Herb S.
Threads: 7
Thanks folks! I'm obviously underestimating there durability! I read the other thread and it sure looks like the Mothers worked pretty well. I've got Novus as well just didn't want to use it on the Bakelite. I wondering now why i was so leery of using much of anything.
Thanks again ...very good information.
Jeff
Threads: 8
City: Chicago,illinois
I agree with TAB10672 "I first clean them with purple power (best cleaner I have ever used)"
That stuff works on BBQ grills also!
Threads: 54
City: Lexington, KY
I've had a cleaner like 409 dull Bakelite knobs before. Now I just spay them liberally with a furniture polish, let them soak, clean any nooks, crannies, or crevices with a soft toothbrush, and they come out looking like new.
Threads: 7
Thanks Eliot,
My recollection is something on that order...because of what the bakelite is made out of compared to plastic.
I like the furniture polish idea.
Threads: 55
City: Evanston, IL
I use Excalbur paste car wax with a soft cloth and minimum of paste.
Also use a very soft toothbrush for the cracks and grooves.
Chuck
Threads: 7
Thanks Chuck ...I was just looking at using some paste wax....the particular ones that brought this up are the thumb wheels on a 42-400 that have dirt/grease in the notches....have to pick up a soft toothbrush. I'm guessing the bakelite is fairly soft...
Threads: 111
I tried my wife's ultra sonic cleaner last night (don't tell her). I had to run it three cycles, but it worked great.
Eric
(This post was last modified: 01-09-2014, 10:10 AM by
Eric Adams.)
Threads: 7
Cool Eric! Trouble with the big consoles it is not easy to remove the thumbwheels is not a simple task so have to do it in place.
