Threads: 2
City: Caldwell,Idaho
I replaced the cartridge in the photo and the sound is clear but I can't get the (volume) sound high enough. The radio volume control works ok.Is there some way to increase volume other than turning knob?
If the shielded cable is not grounded would that make a difference ?
Threads: 310
City: Kings Park NY
have someone move this to electrical forum and they will be able to help. I am useless with this topic.
AC: 4 DC: 1
Threads: 2
City: Sedona, AZ/Placentia/CA
Lumberman, if the radio volume is fine (loud enough) and the phono is weak, it suggests that perhaps your replacement cartridge is either weak or perhaps of the wrong type. Cartridges have a wide range of output voltages depending upon construction. Selecting the proper voltage output is fairly important.
Can you advise what cartridge you installed?
Refer to the schematic as to where the shield should be tied. That may or may not be a problem. It appears the shield is grounded to the changer base.
http://www.nostalgiaair.org/PagesByModel...013612.pdf
Jerry
There are several types of cartridges some have much higher output than others. I would suspect that you have a cartridge that has a low output or is a low impedance output. What cartridge are you using??
Threads: 2
Jerry and Terry, thank you for your replies. The cartridge I installed is a Astatic 32 it states on the box that it replaces Astatic 34;l-24-a;l-36-a;l-82-v;l-92-a. If this is the wrong type where do you suggest I look for the right one,can you test the cartridge for voltage out put. The cartridge I replaced is a Shure crystal pickup cartridge P907, below that it states 35-2643. Tim
According to the schematic the shield is grounded to the turntable chassis and not at the radio end.
Jerry
