Field coil repair.
#46
I can see one reason that the spider may have been buzzing, where is the washer that goes under that center screw? I've never seen a 45 RPM adapter style spider that did not have a washer under that screw. If it's missing the screw may have bottomed out and the spider may be just slightly loose in the vertical direction. Even if it isn't loose there should still be a flat washer under that center screw to spread out the pressure, otherwise it may work it's way through that thin cardboard with use.
The washer is there, it is under the spider between it and the pole. Although a thin one. I saw it when I tried to unscrew the screw to loosen the spider, the washer came from under it so I had to push it back.
