Philco 112 speaker specifications?
Do you know the field coil specifications for the speaker in the late model Model 112 with the '47 output tubes?  Somebody gutted the speaker in mine, and used one winding of some puny transformer in place of the field coil.
Web site: http://www.masekconsulting.net
Radio Photos: http://www.photobucket.com - album id FStephenMasek
If you haven't already, check Ron's spreadsheet of Philco speaker specs (speakers.zip) which can be found here:
http://philcoradio.com/phorum/showthread.php?tid=215
Thanks! The clown who worked on it previously used a winding with just a few hundred ohms resistance, when the correct choke should be 3,200 ohms. That would have made B+ way too high.
 Clearly something went wrong with the speaker field coil in this set, which was why they attempted to make a choke or of a small transformer. Either it was damaged by a shorted filter cap or the winding just failed mechanically for some reason. In any event it's the inductance that matters not the DC resistance, the DC resistance of a proper iron cored choke can be lower then a type H Philco speaker and still work as long as it has the same number of Henries. It would be easier just tracking down a replacement H series speaker rather then rewinding the field coil, but if the original speaker is otherwise intact, and you can get the bobbin out of the frame to rewind it, why not give it a go just for the experience?
The original speaker was gutted, as I wrote above. The end of the field coil enclosure and mounting bracket closest to the cone was drilled out to make room for the magnet of a PM speaker fastened into the old basket.
Yes, I should have written about the Henries, and I do have a meter to measure Henries, but do not know the specification of the original in Henries, just the DC ohms listed on the spreadsheet. There is no way the one winding of the small transformer the hack used would have the same rating in Henries as the large old field coil.
Hi SQ55, A strange issue indeed!  Just so I have you straight, on a dim bulb you get normal operation after the set war...MrFixr55 — 12:44 AM
schematics
I think mseno is talking about cap# 27 which is a multisection but in a paper tube. In cases like that I've usually be ...klondike98 — 11:25 PM
schematics
Ohrenet  :roll: For their price I would chase a fly in a field.  :twisted:Vlad95 — 11:21 PM
A bit more work on the Motorola. I got the repro battery together right up until I realized the snap clips on the top o...klondike98 — 10:45 PM
schematics
Often restuffed. If a twistlock, Hayseed Hamfest makes modern replacements. morzh — 09:18 PM
schematics
Looking for a multi-sectional 8+16 mfd cap. Can't find any suppliers that carry it.mseno — 08:45 PM
schematics
Richard, thanks so much, greatly appreciatedmseno — 08:39 PM
I'm starting to restore a Philco 16X, I need spare parts. Please, help me find ...
Peter; I believe that the "A" suffix means that it has as 25 cycle power transformer, not all Canadian sets...Arran — 07:05 PM
I am back tracking on my resistors as the one that burned based on the old one's resistance was correct but another resi...osanders0311 — 05:34 PM
"So you can see how Important it is to identify parts with the schematic, especially when you have multiple parts o...osanders0311 — 05:23 PM
