Tube tester covered with Tolex
Ah HAH! A Precise 111 tester.
Those are an excellent instrument. In my opinion, they can do everything a Hickok 539 can do. AND it uses a 5KHz signal to develop Gm, vice the 60Hz signal used by nearly every other tube tester manufacturer except Weston.
If you have the opportunity, try using a solid state replacement tube for your 5U4 tube in the Precise. Without the 3A filament drain on your transformer, the instrument is able to measure high current tubes with less "sag," as it uses the "Hickok circuit."
I just pick a Precise 111 up,,from antique store $20.00,,,someone ,,did a real hack job on it,,,got terminals ,,all over the middle top section,,,Have not gottin into it yet,,,
Well... the bad thing is that many Precise 111s were "kit" sets, and some kit builders were better than others. AND then you have the previous owners who have never heard of the concept "if it ain't broke, don't fix it."
IF you can get it working properly, it is an excellent instrument. If it comes in a full case with lid like the one in the photos, it is probably a "factory wired" model. The ones that came in a metal case with no lid were usually the kit models.
Three bits of advice: 1. The chassis and control panel are flimsy, make sure you have it braced when wotking on it out of the cabinet; 2. The potentiometers/rheostats used were cheap. Make sure they are all in good shape; 3. The "slide switches" on either side of the lower row of seven knobs are also prone to failure.
Welcome back, Tom! Icon_wave
Have you ever heard Red Green's variation on that theme - "If it ain't broke, you're not trying?" Icon_wink
How many amps a man can have? I say, as many as the space can hold.morzh — 10:01 AM
Value of capacitor
>>>It currently has an .005 1000 volt electrolytic that is at least 40 years old. That needs to go. There i...morzh — 10:00 AM
One irritating little amp - VM 557
The VM amps were kinda weird, but as you say, they did work well until they didn't. I just got a bag full of new tube so...TV MAN — 08:56 AM
I have a pair of Mk3 Dynas and they always sounded great with plenty of punch. 6550 is the same as a KT88 except usually...TV MAN — 08:45 AM
philco predicta
As Mr. Fix says, this is a live chassis so without an isolation transformer, it can be dangerous to work on. There's goo...TV MAN — 08:33 AM
Value of capacitor
If this helps you sort it out just remember 10,000 mmfd or pf = .01 mfd. So 5,000mmfd = .005 mfd.Radioroslyn — 04:23 PM
Value of capacitor
OP here- the parts list calls for an .005 1000 volt mica. It currently has an .005 1000 volt electrolytic that is at lea...bridkarl — 02:09 PM
Value of capacitor
Maybe it's one of those paper caps that is wrapped in a mica-lookiing case.RodB — 01:51 PM
Value of capacitor
I also was wondering what the post about using polarized caps had to do with the subject? The cap is 5nF, does not exis...morzh — 10:22 AM
Value of capacitor
The OP stated that there is an electrolytic in the circuit in place of the coupling cap and wondered what effect it has....RodB — 09:53 AM
There are currently 1906 online users. [Complete List]
» 3 Member(s) | 1903 Guest(s)
