Philco 610, bakelite condenser voltage rating
Circuit diagram for this radio is at http://www.nostalgiaair.org/pagesbymodel...013800.pdf
Condenser 32 is a dual 110 mmf condenser in a bakelite block. The number on the block is 8035DG. The working voltage rating for these condensers is 1200v according to the info at http://www.philcorepairbench.com/bblokcap.htm. I put 500 volt caps in this block before realizing what the listed working voltage is. Am I ok or do I need to change the caps to the higher voltage rating?
Bob
These two capacitors only see a few volts. 500 volt caps will be just fine.
M R Radios   C M Tubes
(12-29-2016, 10:10 PM)Steve Davis Wrote:  These two capacitors only see a few volts. 500 volt caps will be just fine.
Thanks Steve
Rogers Majestic R-646
You can bypass the interstage transformer by disconnecting the primary, connect a load resistor of about 10k - 20k to th...RodB — 09:40 AM
So, here's Prince on stage halfway through Purple Rain when he stoops down to his tech and says "Rod, pull out that...RodB — 09:17 AM
Today I finished inspecting all the parts. The result is not very pleasing. The first positive news: 1) The power tr...Vlad95 — 11:40 PM
Well, found muh culprit. After using socket test adapters and finding voltages all ok, swapping 6V6s, no avail, swapped ...TV MAN — 11:18 PM
Philco 89 Code 123 Osc Coil
There are currently 1052 online users. [Complete List]
» 3 Member(s) | 1049 Guest(s)
