Need Philco 46-350 parts and advice
Hello everyone. I just joined and just acquired my first Philcos, a 46-350 and a 41-250.
I need the glass dial scale for a Philco 46-350. I also need to find some feet to replace what is left of the old ones. Any ideas? The four-section can was replaced with cardboard cans, so I also could use an old capacitor and support bracket/clamp.
Which paint color code do you think is best for the metal handle attachments?
Does anyone know the name of that exterior covering material? Do you also know a source for it? My 46-350 is OK, excpet for one small hole, but similar material was used on some portable record players I have.
Web site: http://www.masekconsulting.net
Radio Photos: http://www.photobucket.com - album id FStephenMasek
Hello,
I have a 46-350 parts set. I know I have a good dial glass. I will try to remember to look tonight to see if I have the other parts you need. I don't remember if I kept the cabinet or not.
Sean
WØKPX
Sean - someone else is selling me an entire part set, but thanks for checking.
Nice job on the battery, Bob. Can the box be opened to replace the 9 volters?RodB — 11:32 AM
Thank you for the detailed response MrFixr. To clarify, the hum starts when the tubes are fully warmed up, and goes a...sq65 — 09:15 AM
MrFixr The chassis, if there is no ground pin in the AC plug, due to the Y-caps from L/N to the chassis, is at 60VAC re...morzh — 08:47 AM
schematics
thanks I'll try the polar caps seperatelymseno — 07:38 AM
Hi SQ55, A strange issue indeed!  Just so I have you straight, on a dim bulb you get normal operation after the set warm...MrFixr55 — 12:44 AM
schematics
I think mseno is talking about cap# 27 which is a multisection but in a paper tube. In cases like that I've usually be ...klondike98 — 11:25 PM
schematics
Ohrenet  :roll: For their price I would chase a fly in a field.  :twisted:Vlad95 — 11:21 PM
A bit more work on the Motorola. I got the repro battery together right up until I realized the snap clips on the top o...klondike98 — 10:45 PM
schematics
Often restuffed. If a twistlock, Hayseed Hamfest makes modern replacements. morzh — 09:18 PM
schematics
Looking for a multi-sectional 8+16 mfd cap. Can't find any suppliers that carry it.mseno — 08:45 PM
There are currently 1279 online users. [Complete List]
» 1 Member(s) | 1278 Guest(s)
