Padded Feet for Philco 38-15
Ron,
1. I have a Philco 38-15 that has four padded feet. They look like a thumb tack and are just slightly bigger. On the underside is inscribed MATTATUCK WATERBURRY. Do you know if replacements are available?
2. I also need a back for a Philco 40-124. And the correct grill cloth pattern.
Thank you.
David G. Woodward
WildDog Wrote:1. I have a Philco 38-15 that has four padded feet. They look like a thumb tack and are just slightly bigger. On the underside is inscribed MATTATUCK WATERBURRY. Do you know if replacements are available?
If these are the same feet as Philco used on their cathedrals and tombstones (and I suspect they are), these are no longer being manufactured (as far as I know). Many cabinet refinishers, such as Barry Jones, use small circular stick-on felt pads instead which do a better job of protecting the furniture they sit on top of.
Quote:2. I also need a back for a Philco 40-124. And the correct grill cloth pattern.
Sorry, can't help you on the back. I suggest you put an ad in the Philco Wanted section.
As for the cloth, that particular pattern is not being reproduced. A similar pattern is #8 from Radio Grille Cloth Headquarters.
http://www.grillecloth.com/
The 40-124 in my site's Gallery does not have the correct cloth for this reason. The correct pattern may be seen on the 40-90CB:
http://www.philcoradio.com/gallery/1940a.htm#e
This type of glide is available. A little bulky, though.
http://www.floorsaverglide.com/catalog/i...p?cPath=27
http://www.allglides.com/feltpads.html
[Image: http://www.floorsaverglide.com/catalog/i...nailon.jpg]
I use a nail-on plastic type from McMaster-Carr.
[Image: http://www.mcmaster.com/catalog/116/gfx/...13tp2s.gif]
Thank you all for your help.
Need Help to ID this radio 11 tube Philco
Yes the 16B as morzh pointed out. Specifically its the January 1935 model version of the 16B. There are a couple earli...klondike98 — 11:51 PM
48-482 rear panel help
Welcome to the Phorum, keithchip! How far you take a radio on cabinet restoration is a matter of personal preference. ...GarySP — 11:28 PM
I've recently finished the internal restoration of a locally purchased Philco 48-482. The cabinet is in ok shape except ...keithchip — 10:28 PM
Welcome to the Phorum, Ken! Lots of help here for all of your restoration questions. Take care and BE HEALTHY! - Gar...GarySP — 07:59 PM
Thank you. I went to your online library and found 2 schematics. I will download and compare to components!Ken D. — 06:31 PM
It is a 16B tombstone.morzh — 06:13 PM
David - sorry, I reread your post and finally saw THD - now the % figures make sense. Thanks for explaining. The PSU...EdHolland — 06:06 PM
Hi Everyone, New member but have been reading this for awhile for tips! Vaccum tubes were before my time so bear with ...Ken D. — 06:03 PM
My Philco 37-116 Restore
Thank you MrFixR55, I appreciate your comments very much. I do not detect much hum if any so I will be staying with the ...dconant — 05:15 PM
Hi DConant Yes, you can replace chokes with resistors.  You do stand the risk of increased hum.  the solution is to inc...MrFixr55 — 04:23 PM
