Philco 41-221 Tenite Bezel
I just started restoration of a 41-221. I need to know how to remove the clips holding the tenite bezel on the cabinet. I didn't want to get too rough for fear of damaging the bezel.
So here's a couple photos of the bezel and clips.
Looks like you just need a pair of angled needle nose pliers to slip into the clip and give a squeeze and a giggle.
I was able to remove them using a small pair of long nose pliers. There wasn't much clearance to get the pliers under the clip but once I got a grip on it I was able to pinch and rock it back and forth. Looking at the photo, you can see that each side of the clip has a gripper barb to hold it in place.
Restoring Philco 96
Restoring Philco 96
Restoring Philco 96
My Philco 37-116 Restore
I managed to open up the Expander Unit and replace the grid cap wires. Tested the connections found they looked good and...dconant — 12:19 PM
610B Oscillator Questions
I've included a picture of the 'actual' schematic I created. I double checked several times and it appears to be accur...Tubester — 09:26 AM
First Radio restoration
Hi, welcome. I did a 40-130 a few years ago. I was very surprised at how well it performed. Just take care with that sp...Stan the Man — 07:20 AM
Restoring Philco 96
Situations of the like are not pleasant. Life is inevitable. Best of luck to you. I have two 76 chassis, in different ...Stan the Man — 07:12 AM
There are currently 1908 online users. [Complete List]
» 1 Member(s) | 1907 Guest(s)
