Model 19 (89) Chassis Washer Thickness
What is the correct thickness (new) for chassis washers for the model 19 (code 126) - I assume a model 19 chassis is almost the same as a Philco 89? It appears that the choices at http://www.renovatedradios.com/ are 7/8"d x 1/4"t, 7/8"d x 3/8"t, or 1"d x 1/4"t. It appears that the recesses in the cabinet will just accomodate 1" diameter washers, but 7/8"d could also be used.
But the thickness choices are 1/4" or 3/8", unless you guys know of another source. I just want the correct chassis height.
Thanks!
According to Mark Oppat at Old Radio Parts http://www.oldradioparts.net/rubber.html his part number PH-184 is correct for most 1930-1938 Philcos. These are 7/8 diameter by 3/8 thick.
I have successfully used both the 1/4 and 3/8 thick by 7/8 diameter on Philco 90's.
Ed
Best to use the one from the library on this site, then when you refer to part 30 we know which part you are referring t...RodB — 03:32 PM
52-942
Welcome to the Phorum, Ken! The included schematic for your set is located in the Philco Library at the bottom of our Ho...GarySP — 03:13 PM
Video Source for Predicta
You can also source a used VCR and use that as a modulator to feed your DVD source into.TV MAN — 02:57 PM
52-942
Just received my 52-942. Its a handsome set. When I opened the back to examine it I noticed there are not connecting wir...Ken Arroyo — 02:54 PM
"Your radio tubes get these voltages from the power transformer secondary windings. The A voltage is supplied by th...osanders0311 — 01:40 PM
Please correct me if I am wrong, while working on this radio I noticed under the chassis where the bottom of the tubes p...osanders0311 — 01:28 PM
"BTW there's a 2.2k resistor from B+ to one of the XXL tubes so you have to identify those resistors before you rep...osanders0311 — 01:04 PM
BTW there's a 2.2k resistor from B+ to one of the XXL tubes so you have to identify those resistors before you replace t...RodB — 11:08 AM
Okey dokey, let's get on the wayback machine. Back when radios were running on batteries, they were powered by three DC ...RodB — 10:34 AM
Meter is a DMM (Brymen BM-257 to be exact) Voltage being measured to the chassis Yep, just double-checked 'emsq65 — 10:22 AM
