Help with a 38-9
Ok I went to replace the rubber bushings that go between the main chassis and the air capacitor and two wires broke off Im pretty sure where A went and soldered the new wire on but B im not sure there was a wire (small grey one coming off from where B is now soldered labeled Cbut it was just hanging there) im not sure that is where it goes any help would be most appreciated Thanks doug
[Image: http://i1095.photobucket.com/albums/i474...010011.jpg]
[Image: http://i1095.photobucket.com/albums/i474...009911.jpg]
Looks to me like you have one connection to the grid cap of the 6A8G tube, and one connection to pin 5 of the 6A8G tube. I only see the two connections on the schematic.
[Image: http://i1129.photobucket.com/albums/m501...s/38-9.jpg]
[Image: http://i1129.photobucket.com/albums/m501...s/6a8g.jpg]
If there was a third one maybe it was a ground? Most of the time the ground are copper braid that usually soldered to the chassis.
Schematic here:
http://www.nostalgiaair.org/PagesByModel...013262.pdf
-Keith
I looked thru the documents and did not see one. Might have missed it though.Jim Dutridge — 07:16 PM
Please tell me this was it, I replaced resistor 27 and it's playing on the broadcast band. I am afraid to change the ban...osanders0311 — 06:12 PM
There are currently 1134 online users. [Complete List]
» 3 Member(s) | 1131 Guest(s)
