  • 1 Vote(s) - 5 Average
Philco 45 Butterfly Restoration Chronicles....Finished
#46
Here is a picture that is not the best lighting, I will take it outside later today for some better pictures. I have put it next to other radios that have that very dark look but you just know that its not black and this one still looks black. There are none of the tell tale signs of refinishing that makes me believe it is the original finish. I have not seen another so have nothing to compare to.
Gregb
I have an 18b with the same "style" finish that is original and although pictures you see make them look black this one is a really really dark brown. Actually the only way to see its brown is to hold something black against it in good light.
#48
Kirk, you brought those radios back from the dead before, and you'll do it again with even better results this time. Sometimes, after something like this happens, you just need to walk away and take a break for a while.
Philco model #20
Hello again fellows , well I powered up the set this evening after I had changed every cap and resistor in this set and ...onlyrick — 09:34 PM
Yes - better it happened on the repair bench than returning to the owner. The other question is - do I also dissect a...EdHolland — 09:08 PM
That's a bummer but get them now. Paul BPaul Philco322 — 08:27 PM
I completed the insulation on the cabinet interior (Al foil and hi temp silicone rubber), and reglued the speaker gasket...EdHolland — 06:18 PM
Tim - Photos of 8 octal tube sockets. (Top and bottom) Send me a PM if you're interested.RodB — 04:11 PM
VTVM meter moves when my hand is next to it & not on
Haha! I hope so. It seemed rather lost and forgotten languishing in the frozen Northeast of England.EdHolland — 02:36 PM
Ed - it's in the Cayman's enjoying the good life.RodB — 02:14 PM
Static electricity - but the other chaps beat me to it again. I've seen this before with analogue meters. I've also ...EdHolland — 01:56 PM
There are currently 1201 online users. [Complete List]
» 5 Member(s) | 1196 Guest(s)
AvatarAvatarAvatarAvatar
