  • 1 Vote(s) - 1 Average
Planning on restoring a Model 46-1201 (Build 125) Bing Crosby in a few months, and am trying to locate a few parts beforehand.  I found on another post the part number for a replacement Idler Wheel for the M-7 turntable.  However, has anyone found a suitable replacement for the 2 "sleeves" on the guide rollers?  Mine appear quite worn, and have seen better days. If there was a replacement available, I'd like to swap those out.  I also have info from other posts regarding the needle assembly in case I need to change cartridges.  Any other issues with these units that I should be aware of ahead of time other than the standard replacement of caps and any resistors as needed?  Thanks!
Nice job on the battery, Bob. Can the box be opened to replace the 9 volters?RodB — 11:32 AM
Thank you for the detailed response MrFixr. To clarify, the hum starts when the tubes are fully warmed up, and goes a...sq65 — 09:15 AM
MrFixr The chassis, if there is no ground pin in the AC plug, due to the Y-caps from L/N to the chassis, is at 60VAC re...morzh — 08:47 AM
schematics
thanks I'll try the polar caps seperatelymseno — 07:38 AM
Hi SQ55, A strange issue indeed!  Just so I have you straight, on a dim bulb you get normal operation after the set warm...MrFixr55 — 12:44 AM
schematics
I think mseno is talking about cap# 27 which is a multisection but in a paper tube. In cases like that I've usually be ...klondike98 — 11:25 PM
schematics
Ohrenet  :roll: For their price I would chase a fly in a field.  :twisted:Vlad95 — 11:21 PM
A bit more work on the Motorola. I got the repro battery together right up until I realized the snap clips on the top o...klondike98 — 10:45 PM
schematics
Often restuffed. If a twistlock, Hayseed Hamfest makes modern replacements. morzh — 09:18 PM
schematics
Looking for a multi-sectional 8+16 mfd cap. Can't find any suppliers that carry it.mseno — 08:45 PM
There are currently 1105 online users. [Complete List]
» 2 Member(s) | 1103 Guest(s)
