Handy Hint for those missing lamp jewels in 1940-42 Philcos
Many 1940, 1941 and 1942 Philcos that have a door over the dial also once had a red indicator lens in the cabinet, under the dial door, to indicate if the radio was "on" or not.
This indicator lens (jewel) was made of Tenite, as were many of the plastic parts used in 1941-42 Philco radios. As you know, Tenite has a tendency to shrink over time, and it appears most of these jewels have become lost due to the Tenite shrinking.
Someone over at ARF posted a helpful hint for those looking to replace this missing indicator lens. I wanted to direct your attention to this.
http://antiqueradios.com/forums/viewtopic.php?t=124734
Thanks for the suggestion. Bob
Regarding picture 5 on page 1 of this thread this capacitor is #40 on scematics diagram - 4mF+4mF. Black wire is "-...Vlad95 — 09:01 PM
That's a dual 4 MFD, red and green are both 4mfd and black is common negative. You should be able to see them in the pow...RodB — 08:58 PM
Can anyone help me figure out a capacitor that has 3 wires coming out of it red and green on one side and a black wire o...osanders0311 — 08:14 PM
The transformer may be the last cause of voltage drop. This level of voltage drop is not too big. Conduct additional te...Vlad95 — 07:16 PM
Well I have found 315v on the rectifier when cold. Drops off to 280 after 15 minute warmup. Checked pin 3 on both 6F6 t...murf — 04:14 PM
Thanks for the replies, I will check these ideas out and report back. murfmurf — 03:18 PM
Sorry, my mistake. murfmurf — 03:07 PM
MrFixr Honestly, I haven't done that yet and do not want to screw up the threads; maybe you could do it, or we could...morzh — 12:48 PM
Two small radios from France. Restoration and review.
Greetings; I think that it's possible that the assortment of components was the result of post war parts shortages, a...Arran — 12:18 PM
Unfortunately I can't inject any audio into the volume control. It is in the primary circuit of the antenna coil, not in...Stormlord5500 — 09:32 AM
There are currently 305 online users. [Complete List]
» 3 Member(s) | 302 Guest(s)
