Does anyone know if you can still get theses. And some of the color codes are gone . What do you look for to order replacements .
I seen the site at the repair bench . Does Chuck sell them. Icon_rolleyes
Thanks Kent.
Hi Kent
No, Chuck does not sell them, but here's a few places that do:
Mouser Electronics - http://www.mouser.com/
Radio Daze - http://www.radiodaze.com/
Vacuum Tubes, Inc. - http://www.vacuumtubesinc.com/
Jim Cross, owner of Vacuum Tubes, Inc., is another of the "good guys" in the radio hobby and is deserving of our support.
Basically, you need to know the value of your original mica caps and then order new micas that are at or as close to the original value as possible.
I think most micas have a working voltage of 500 volts DC, which is plenty for nearly any radio application. Some are rated at 300 volts DC which is still enough for many radio circuits using mica caps.
Would an output transformer if weak, cause the problems I am seeing with lower B+ voltage? murfmurf — 01:22 PM
Hello murf! I merged the threads. Please do not start new threads regarding the same radio. Take care, - GaryGarySP — 10:21 PM
Regarding picture 5 on page 1 of this thread this capacitor is #40 on scematics diagram - 4mF+4mF. Black wire is "-...Vlad95 — 09:01 PM
That's a dual 4 MFD, red and green are both 4mfd and black is common negative. You should be able to see them in the pow...RodB — 08:58 PM
Can anyone help me figure out a capacitor that has 3 wires coming out of it red and green on one side and a black wire o...osanders0311 — 08:14 PM
Two small radios from France. Restoration and review.
Greetings; I think that it's possible that the assortment of components was the result of post war parts shortages, a...Arran — 12:18 PM
Unfortunately I can't inject any audio into the volume control. It is in the primary circuit of the antenna coil, not in...Stormlord5500 — 09:32 AM
Sounds good Gary I'll do that. I have plenty of stuff like that I can scrounge up. I am still kind of new to all this so...Stormlord5500 — 08:47 AM
Philco Battery-WWII vintage
Seems to me that this a general purpose or radio filament 6V battery of very high amp-hour capacity and very high "...MrFixr55 — 08:08 AM
You should be able to inject an audio signal such as from a CD or mP3into the radio at the volume control. The set will...MrFixr55 — 08:14 PM
There are currently 537 online users. [Complete List]
» 1 Member(s) | 536 Guest(s)
