Clear Lacquer On Decals?
I am finishing up a cabinet for a Philco Radio-Phonograph Model 46-1201.
Question: Does anyone know if its OK to spray a couple coats of clear lacquer over the new decals after they are applied? Or will doing that ruin or yellow the decals?
Thanks
A couple coats of clear lacquer are essential to help protect those decals. A careful application of Micro Sol to each decal before applying more lacquer should make them smoother in appearance.
Excellent. Thanks!
Spray it on!
If you are brushing your finish (as I am) please save yourself my headache from last night and spray several protective layers over that decal first.
My decal fragmented badly under the brush, even though I gave it 2 coats of Testors clear lacquer first. Not sure what to do now, aside from whip out the 320 paper again...
Rogers Majestic R-646
Vlad; I was just reminded of something else, I'm not sure why but many Rogers built sets do seem to have open primari...Arran — 04:40 PM
Thanks RpdB I don't think there's much difference with interstage transformers of different models other than dimersion...Vlad95 — 03:27 PM
Vlad; I looks like your set has the same problem that mine did, both a bad output transformer, and a bad audio inters...Arran — 03:21 PM
Ouch! Not often the secondary takes a hit. Wish there was a better solution. I have a good interstage transformer but it...RodB — 02:59 PM
By the way, the bypass you suggested is a rare solution in some circuits. For example, this schematics solution is used...Vlad95 — 01:43 PM
No, you are wrong, because you did not know the details. Unfortunately, only ONE winding out of six is intact in both t...Vlad95 — 01:14 PM
The output 45s are still in push-pull because the transformer secondary winding is still in the grid circuit providing o...RodB — 11:52 AM
Thanks RodB for the help. But this is not a real solution to this situation, not even a temporary one. Because the firs...Vlad95 — 11:34 AM
I was going to check the voltages as you suggested and hooked it up to my dim bulb. It appears I have a short. The bul...bobclausen — 10:34 AM
You can bypass the interstage transformer by disconnecting the primary, connect a load resistor of about 10k - 20k to th...RodB — 09:40 AM
There are currently 1006 online users. [Complete List]
» 3 Member(s) | 1003 Guest(s)
