Philco 42-355
#31
OK.....got it out...intact. I have disconnected the wire on the right that goes to the speaker. The next question is about all of the decals and papers stuck on the inside of the cabinet. Some have the model number and other info. I assume I want to preserve these......but how? Do I just cover them with some wide clear tape? I plan on cleaning the interior of the cabinet.
#32
"HELLO" your post #30. Look..... I told you up front I wasn't good with computers....see my post #3. The pic was sent before the text of my question so it was out of order from my end and I resent the question. Sorry to get you fuzzed up. Remove me from your forum.
Best Mike
#33
Sigh...
Sorry you got upset, but I had just told you how to remove the FM antenna plug. When you asked again I thought you were ignoring my post.
Have a nice day.
Don't get upset Mike, often people are responding at the same time makes for some out of sequence messages. As for your stickers, cover them with some wax paper taped down to the wood. No tape on the label.
Jerry
Rogers Majestic R-646
You can bypass the interstage transformer by disconnecting the primary, connect a load resistor of about 10k - 20k to th...RodB — 09:40 AM
So, here's Prince on stage halfway through Purple Rain when he stoops down to his tech and says "Rod, pull out that...RodB — 09:17 AM
Today I finished inspecting all the parts. The result is not very pleasing. The first positive news: 1) The power tr...Vlad95 — 11:40 PM
Well, found muh culprit. After using socket test adapters and finding voltages all ok, swapping 6V6s, no avail, swapped ...TV MAN — 11:18 PM
Philco 89 Code 123 Osc Coil
There are currently 918 online users. [Complete List]
» 3 Member(s) | 915 Guest(s)
