Philco 37-611
Steve do you have a signal generator? If so you could try putting a 470kc mod. signal in the IF stage then det./ocs stage moving backwards toward the antenna connection to see where you lose it.
I assume you have checked all the tubes and I would also clean the band switch very well.
Did you have an antenna hooked up? Just throwing out some ideas you could try. I'm by far no expert on these radios.
There are guys and at least one gal ,Brenda ,on here that probably have forgot more than I will ever know about this hobby.
Good luck
(08-06-2015, 12:07 PM)Mike Wrote:  Steve do you have a signal generator? If so you could try putting a 470kc mod. signal in the IF stage then det./ocs stage  moving backwards toward the antenna connection to see where you lose it.
Good luck
I found something else on this radio
It varies from the 2 schematics I found online.
In the center of the chassis there is an additional bakelite condenser this is not shown on the chassis layout or in the parts list.
Does anyone know if there is a later or earlier version of the 37-611 that shows this change?
Just trace it.
Nice job on the battery, Bob. Can the box be opened to replace the 9 volters?RodB — 11:32 AM
Thank you for the detailed response MrFixr. To clarify, the hum starts when the tubes are fully warmed up, and goes a...sq65 — 09:15 AM
MrFixr The chassis, if there is no ground pin in the AC plug, due to the Y-caps from L/N to the chassis, is at 60VAC re...morzh — 08:47 AM
schematics
thanks I'll try the polar caps seperatelymseno — 07:38 AM
Hi SQ55, A strange issue indeed!  Just so I have you straight, on a dim bulb you get normal operation after the set warm...MrFixr55 — 12:44 AM
schematics
I think mseno is talking about cap# 27 which is a multisection but in a paper tube. In cases like that I've usually be ...klondike98 — 11:25 PM
schematics
Ohrenet  :roll: For their price I would chase a fly in a field.  :twisted:Vlad95 — 11:21 PM
A bit more work on the Motorola. I got the repro battery together right up until I realized the snap clips on the top o...klondike98 — 10:45 PM
schematics
Often restuffed. If a twistlock, Hayseed Hamfest makes modern replacements. morzh — 09:18 PM
schematics
Looking for a multi-sectional 8+16 mfd cap. Can't find any suppliers that carry it.mseno — 08:45 PM
There are currently 1271 online users. [Complete List]
» 1 Member(s) | 1270 Guest(s)
