Philco model 77
http://rs32.pbsrc.com/albums/d5/flathead...0&fit=clip
Here's a photo of the ever elusive parts number page for this set, mine shows a different part number from the 2766, mine shows a 2848, is this the same opt?
I couldn't find that #.  Look here  http://philcoradio.com/phorum/showthread.php?tid=215    under spkr zip.
Now I think I've got it!
Tried to open that thread, it says it doesn't exist
Go to Philco Downloadable Files then Philco free download files it's in there under spkr zip file
Here's the link directly to the speaker file:
http://www.philcoradio.com/phorum/attach...p?aid=5181
It should directly download the speakers.zip file to your PC, then you need to unzip it to read it.
I finally found it and downloaded it, however last night I pulled the opt up to get a better look at it and have 2 loose solder joints. I don't know if this is the problem or not but I'll re solder and try again.
So I've gone back and soldered the broken contacts on the speaker to see if I'd get a different reading, it didn't seem to change the readings or voltages on the 45 tubes so it looks like I am now on the hunt for either a new speaker assembly or a new functioning output transformer. What's going to be the best way try to see if anything comes across ebay eventually or try a looking for ad?
Where did the rest of the thread go?
87 - http://www.philcoradio.com/phorum/showth...?tid=16059
77 - right here Icon_smile
There are currently 2440 online users. [Complete List]
» 1 Member(s) | 2439 Guest(s)
