Threads: 3
City: Chicago
State, Province, Country: IL
I have a Bogen DB10 with two 4x5uF multisection caps. The lowest value replacement I can find is a 4x10uF by CE.
Would this be an appropriate replacement?
PDF schematic attached.
I need more Axial electrolytics.......
Threads: 3
City: Chicago
Screenshot attached.
Image(s)
Threads: 573
If you mean the places where you have 5uF caps (the power filter is 2x10uF) then, yes, they will not adversely affect anything.
Threads: 120
City: Omak
State, Province, Country: WA
Hello notcalibrated,
If this was my Ampifier I would use two 4.7ufd Film Capacitors like these Panasonics that I use that rated at 630 volts They are very good capacitors and only cost couple dollars each .
Image(s)
