Transitone 42-PT2
I rewired a transitone and had great difficulty tuning the IF. I also ended up replacing the IFs wires with 20AWG stranded - is this a problem? Finally tuned it with the aid of a scope on IF2 output. Tuning is off about 10% on the low end, 600kHz is at 660 on the dial. 1600 and 1500 are ok, adjusted per Philco maintenance instructions. Compensator wont get me to 600 on the dial.
1 - Are the Transitone IFs just plain hard to tune?
2 - Could the 20AWG stranded IFs wires have shifted me?
If the wires are the same length more or less, no, they should not de-tune anything.
The tank is in the IF can.
Which doe snot mean you could be sloppy, but changing the type of wire is not important.
There are currently 1788 online users. [Complete List]
» 2 Member(s) | 1786 Guest(s)
