How do I figure what antenna to use
Hi all
I have a Motorola tuner, Icon_surprised. The antenna is missing. Icon_sad I know it had a ferrite rod type of antenna Icon_confused. Now the question Icon_rolleyes to replace the ferrite rod how do I figure what uH I need Icon_confused:. Can anyone help me Icon_wink. Antique parts has three 230 uh, 250uH and 650 uH. HHHHHHHeeeeelllllppppp. Joe
The 230 or 250 should work. The winding can be slid along the rod to adjust the inductance as part of the alignment.
Ok I will try the 250. Thanks for your reply Icon_wave . Joe
With regard to the speaker, unless the cone is so brittle that it crumbles as soon as you touch it I would try to repair...Arran — 04:07 AM
That silver can capacitor is an aluminum electrolytic. You should replace it with an aluminum electrolytic with the valu...RodB — 11:46 PM
There are currently 393 online users. [Complete List]
» 2 Member(s) | 391 Guest(s)
