Threads: 88
City: Tacoma
Started working on the cabinet for the 116B this evening. Got a good look at it. It was UGLY (see first pic). Someone had apparently painted the whole thing with some crappy flat brown house paint, then some sort of plasticized clear coat that flaked off into big flakes when I worked the stripper into it.
You can see in the second pic that after getting through the paint the actual grain started coming out.
In the third pic, you can see that by carefully removing the paint I have gotten through to the pattern underneath. I'm wondering, is this photo finish? It seems pretty resistant to the stripper and my efforts to get the paint off. It would be nice if this were real wood/veneer that could all be saved and worked with.
Also, as can be easily seen, I've reglued the separated sides. I have some work that will need to be done to the bottom in the front, as the cabinet seems to have sat in water or at least a wet location for some time.
Threads: 147
City: Dallas, TX
Hello Brenda, there is no photo finish on that set, one thing you have going for you is that the brown paint has actually protected the wood veneer from the elements. Stop where you are and let the glue dry then remove the clamps and dial frame along with grill cloth , then finish stripping. Be very careful not to damage the veneer when removing old paint and factory finish. If there is veneer already lifting do not get any stripper under the veneer. If you need help with cabinet I can walk you thru it
(This post was last modified: 11-29-2015, 03:17 PM by Fred Taylor.)
Threads: 214
City: Seattle
State, Province, Country: WA
Fred are you sure there is photo finish? A 116B would be s fairly high end set:
http://www.philcoradio.com/gallery/1936a.htm#i
It's also not included in Ron's list of models with Photo finish:
http://www.philcoradio.com/phorum/showth...p?tid=5473
Threads: 147
City: Dallas, TX
(11-29-2015, 03:13 PM)Nathan Slingerland Wrote: Fred are you sure there is photo finish? A 116B would be s fairly high end set:
Hello Nathan I had corrected myself, I misspelt my wording and now has been corrected , my fault sorry  I meant to say there isn't instead of is.
Threads: 214
City: Seattle
Ha ok good. I frequently miss that crucial 'not' when I write emails too.
Threads: 88
City: Tacoma
Anyone got a working email addy for Steve Davis?
Threads: 214
City: Seattle
stevd47@aol.com isn't working?
I emailed him at that address in May.
Threads: 88
City: Tacoma
N/M... I added an "e" where there wasn't one.
Threads: 88
City: Tacoma
Have the cabinet almost completely stripped now, just a few small spots that are resisting my efforts, but they'll come along by and by.
Now that it's so close, I'm REALLY having a hard time understanding why they painted it that gawdawful color:
Tomorrow, I'll take my GOOD camera out there and get another shot. For some reason the cheapie Ricoh I use for snapshots is really making it look washed out, and it really looks much better than the above pic.
Suggestions for working up a replacement for the bottom trim in front?
Threads: 88
City: Tacoma
I see from other pics online that there seem to be two versions, one with a vertical grain and one with a horizontal grain.
Threads: 88
City: Tacoma
Well, what do you guys think? Nothing done to the sides yet, and only a single application of stain on the front and sides, and a wipedown with paper towels.
Threads: 88
City: Tacoma
Gloss black on the trim.. what a pain to mask it off.
First coat of lacquer. Going to be putting on two more coats over the next few days.
Comments? Not too late to start over if I've really made a horrible mistake.
Threads: 88
City: Tacoma
Also looking for pointers on how to smooth out the gloss of the lacquer once it's all applied.
Threads: 337
City: lawrenceville nj
Brenda
that's great looking
wonder why they painted match their décor ?
looks like it will be easy restore
sam
42-345 Resistors
Thanks for the reply.
What I was thinking was that I have the OEM speaker from Little Phil, but the mice and radioac...proftrussell — 01:48 PM |
42-345 Resistors
1. I was about to sayw what you later said you'd like to do. Change the speaker, see if a know good one rattles also. Us...morzh — 01:40 PM |
Good afternoon, folks! A wind of good luck has come! I’ve been quietly waiting to go get the junker 46-480, but I’ve jus...jrblasde — 01:30 PM |
42-345 Resistors
Hello Phriends!
Little Phil is back!
I'd like to say that I took heart from a comment by Morzh (Mike), who, after ...proftrussell — 01:25 PM |
National NC-57 case
For that dent, if it's easy to get to both sides of the sheet metal place hardwood or metal shims on both sides of the d...GarySP — 01:21 PM |
Hello John. I have never met VEF156 and have not even heard of the existence of such a model. Perhaps you are mistaken w...RadioSvit — 11:44 AM |
One irritating little amp - VM 557
Those sand resistors may just be the culprit. I'll swap those and see how it behaves. They looked & checked pretty g...TV MAN — 11:00 AM |
Gloritone 27 Radio
It seems these radios of the 1930s were experiments when it came to antenna signals and getting as many stations as poss...RodB — 10:20 AM |
Hi Peter,
Always praying for peace. Is the VEF156 Stereo or does it have only a mono amp with the 4 speakers? (I assum...MrFixr55 — 10:05 AM |
Gloritone 27 Radio
Hi Dan,
That should work. If it is the primary, it is not tuned. If it is the secondary, you may have to add capac...MrFixr55 — 09:11 AM |
There are currently 1516 online users. [Complete List] » 1 Member(s) | 1515 Guest(s)
