Threads: 144
City: Elko,MN.
Working on a 38-116 code 125 and have a question concerning bakelite blk. number 46.
This is a 4989SG which is listed on the parts list as having a single .1 uf cap.
If you look on the handy reference guide that I printed out from the Philco site, it does not list a 4989SG.
Anyone know what the proper wiring would be as far as the new .1 cap.
Lugs 1 to 2 or lugs 1 to 3 ?
murf
Threads: 20
City: Decatur Alabama
According to Ray Bintliff's book "Philco condensers and more", the 4989SG block contains one .09 cap connected from lug 1 to 3.
Threads: 144
City: Elko,MN.
Guess the parts list is wrong?
Threads: 144
City: Elko,MN.
After looking farther, I see there is a 4989DG that is not listed as well.
Schematic view and the parts list only show 3 blocks instead of the 6 or 7 blks that are used in the chassis.
What's up ?
Murf
Threads: 20
And according to "Condensers and more" the 4989 DG is two .09 condensers, first is lug 1 to 2, second is lug 1 to 3. Lug 1 goes to chassis ground.
Threads: 70
City: Linn Creek, MO
Quote:Guess the parts list is wrong?
.09 or .1 same thing.
M R Radios C M Tubes
Threads: 20
Oh yeah. Close enough for me.
Threads: 144
City: Elko,MN.
OK, thanks for the info Doc.
I guess the others that are not shown on the schematics will have to be done using the number marked on the block.
Wish it were clearly marked on the schematics so there is no guess work involved.
Thanks again,
Murf
Threads: 144
City: Elko,MN.
(04-10-2017, 08:54 PM)Steve Davis Wrote: .09 or .1 same thing.
Kinda figured that was the case.
Any idea why the rest of the blocks are not shown on the schematics ?
Don't want to guess on these, it is too much work to re-do these.
Thanks Steve,
Murf
Threads: 268
I took a look at the schematic and saw only one #46 cap, screen bypass for the IF amp stage. The parts list sez it's a .1mfd (probably 400v) it doesn't say dual so I'm thinking it's a single unit. Have a look at the eyelet to see if the center terminal has a wire coming up thru it.
As mention .09 hasn't been a standard value for a million years.
Threads: 144
City: Elko,MN.
Hi Terry,
Yes I can see the leads coming thru the rivets, but why don't they show all of the Bakelite blocks on the schematics?
Hate guess work.
Murf
Threads: 26
City: Hayward, California
As im sure you all knew... Doc is right on the two cap blocks info. Just wanted to put my 2 cents worth in.
Threads: 268
Ok....
Does resistor #45 connect between the two ungrounded terminal of 46??
Threads: 144
City: Elko,MN.
(04-10-2017, 10:39 PM)Radioroslyn Wrote: Ok....
Yes there is.
Started recapping the blocks today.
So far so good. 3 down and 3 to go.
Murf
Threads: 268
Ok The other cap in that block is #9 a .05 (a 473 in these new fangled numbers). This is what the schematic shows, parts layout sez different. Having a extra .05mf isn't going to make any difference.
(This post was last modified: 04-11-2017, 07:56 PM by Radioroslyn.)
Tim,
nice write up and thanks for sharing !!
Sincerely Richardradiorich — 02:47 AM |
Well, this was a real "Hum-Dinger" :lol: ! This will be kinda long, but hopefully it will help others having t...TV MAN — 01:55 AM |
Shadow Meter Bulb
Phorum members, I am trying to find the bulb # for PHILCO Shadow Meter part number 45-2180 that is from a 37-640 chassis...georgetownjohn — 06:53 PM |
Philco 41-608 changer coupler
3D-printing...short of machining, of course.
Or molding.morzh — 05:20 PM |
Thanks, Morzh.
That solves the issue of the rubber pieces. Now, I need to find a way to replicate the pot metal piec...alangard — 05:07 PM |
12' Philco
If it is 12', either Kareem or Andre would have to jump pretty high to look at the front panel.
Kareem would have an e...morzh — 01:48 PM |
12' Philco
And here's a story about the tires on the truck. Same "no-stoop" guy must have installed these! Take care a...GarySP — 01:17 PM |
Hickok AC51 tube tester
I think they have only shown the secondaries of the transformer.
Two of them feed the rectifiers' filaments.morzh — 12:58 PM |
If the wire inside cans is the gauges you mentioned, the sole reason for that would be mechanical, to stiffen t...morzh — 12:56 PM |
12' Philco
Rod,
Yes, I know, but the Giant Philco is not around anymore either, so I go by whoever was alive fairly recently.
H...morzh — 12:54 PM |
