Enameled wire question.
Good Morning All,
Question 1: Will a lack of an enamel coating on coil wire affect the coil performance?
I'm working on a model 89..open tickler coil. When I un-wound the small coil I used lacquer thinner to try to clean the rotten, melted plastic left over on the Osc. coil...removing the enamel in the process. Icon_thumbdown
Question 2: Has there ever been a reported case of PTSD caused by attempting to restore a Model 89 that uses a 36 tube? Icon_confused
Thanks in advance.
Kelly
"He has all the virtues I dislike and none of the vices I admire." — Winston Churchill
Yes it will. If you wind it densely and it shorts out.
And if you do not wind it the same way it was, it might affect the inductance which may or may not be important.
Thanks morzh.
1.7-3.9 %, a modified Sine wave inverter is around 25%. Most generators from big box stores run 10% at a 50% load. What ...David — 04:06 PM
My Philco 37-116 Restore
I am having a heck of a time doing the alignment on the AM band. I can't seem to dial in the 1500 KC oscillator. I can h...dconant — 03:35 PM
David - I think I understand but what units are you discussing (Low of 1.7, high of 3.9)? Budget constraints for Ham ...EdHolland — 01:43 PM
You're doing great. I wish I could be more involved, but my mind is right now preoccupied with the reason I am here in ...morzh — 12:21 PM
Hope you guys are still with me. I have moved on to the alignment. I completed the IF alignment which was pretty muc...dconant — 10:47 AM
Hello MrFixr55, Thank you for taking the time to explain. I measured 50 volts where you say. Today the 370 volts at ...dconant — 12:51 PM
Oh that sucks. It’s something easily overlooked. Hopefully it’s nothing more than a resistor! Ron462ron — 08:08 AM
Just confirmed that you are correct. It’s the function generator. I connected the signal output probe to one of the inpu...jrblasde — 07:52 AM
Ouch, you may be right. Yes, it is solid state. It’s the signal output of my oscilloscope. May be time to crack that ...jrblasde — 07:27 AM
If you didn’t put a DC blocking cap between the signal generator probe and the plate of the 1st IF it’s possible you ble...462ron — 07:07 AM
There are currently 486 online users. [Complete List]
» 1 Member(s) | 485 Guest(s)
