16B Tombstone Missing Code #
Hi All,
 I have a Philco model 16B Tombstone.  I see in Rider's there is no specific 16B but information dependent on the code #.  All my markings and labels are gone from the radio.  Any suggestions  to pinpoint proper schematic for my particular version of this model?
Thanks
Dan
Danny in Cleveland
Hi Dan - post a picture of the chassis and we should be able to help identify it pretty easily.
is it a 4 or 5 band chassis?
My code 121 cathedral uses the #80 rectifier tube..
He said it is a tombstone, so it must be either a Code 121 or Code 125 (unless someone stuck a console chassis inside).
Code 121 - 5 bands, single tuning knob that pulls out and pushes in for two-speed tuning, QAVC (Quiet Automatic Volume Control = squelch control) with adjusting rheostat in back, vertical mounting power transformer, large rectangular can capacitor bank
Code 125 - 4 bands, dual concentric tuning knobs, does not have QAVC, horizontal mounting power transformer, does not have the large rectangular can capacitor bank
Hi all,
Got around to taking a few pictures.  More worried about the cabinet condition.  Any thoughts on cabinet?  The chassis is un-touched from my rough examination. A few moldy capacitors & off-value resistors.  Probably good to go...certainly a fine radio set in the Philco line in the day!
Danny in Cleveland
You have the later 4-band (Code-125) chassis.
From the under-chassis pics it's definitely seen some service long in the past. Not uncommon - but the first step will be to try and reverse that and figure out how it went originally.
These are great performing sets when fixed up and fully recapped. You definitely want to replace the electrolytics before trying it on a variac or dim bulb tester. It may kind-of sort-of work at that point which will make it easier to go through and recap the rest of the bakelite blocks and replace any out of tolerance resistor.
It should be possible to reglue the front onto the cabinet (can you see how it was originally held together?). And of course it looks like a good candidate to refinish at some point. Icon_smile
I have some car radio service manuals, Riders I think (not to be confused with the big blue binders), so I may see if on...Arran — 01:20 AM
Philco model 40-100
Greetings; Here is an update, I found a listing on fleabay for a similar chassis to yours, and it has a photo of what...Arran — 12:58 AM
Philco model 40-100
Greetings; I think I may have found a clue as to what is missing, from a search I made, there is a rear view of the c...Arran — 12:12 AM
Philco model 40-100
I recently acquired a Philco model 40-100 farm (battery) radio. The radio was in very good condition except the red on f...mhamby — 05:59 PM
Hello, Richard the radio is an AC-2687 Studebaker model. The Philco model is S -5323 and the chassis p/n is S-5523Pdouglaski — 11:52 AM
48-482 rear panel help
The 48-482 is an AC only set as well, featuring a power transformer. While the transformer shouldn’t get “hot”, it is ye...jrblasde — 11:12 AM
I gave a Chrysler/MoPar car radio from 1954, it was made by Philco, and it uses two chassis, one has the power supply an...Arran — 11:06 AM
Hello keithchip. You could make a hardboard back for the set, but make sure you provide plenty of ventilation holes in ...GarySP — 11:04 AM
Welcome to the Phorum, Phil! Lots of friendly help here to assist you along the way! Take care, - GaryGarySP — 10:55 AM
Hi Pdouglasti, Phirst off, welcome to the Philco Phorum, a Phamily Phriendly place phull of phun pholks and all things ...MrFixr55 — 07:37 AM
There are currently 827 online users. [Complete List]
» 2 Member(s) | 825 Guest(s)
