1934 Philco 16B Code 121
Next on the bench is a Model 16, Code 121.
I believe I was able to get the values for everything from available paperwork. Icon_thumbup
The only thing questionable was the values on the tone control, due to the print being so small on the schematic.
I have .09, .15 and .5 as the values. This is part 30-4033, #79 on the parts list, and #80 lists caps as part of 79, part number 06713.
Can anyone confirm the values needed for the tone control?
Also, the large square capacitor filter can. I have the values, but no diagram of the pin connections for each of the capacitors. Can anyone fill me in?
Also, as in the Model 20, should I just use the 600v/630v standard film caps instead of electrolytics?
Thanks for any help. Icon_thumbup
Blessings,
Jeff W.
Jonesboro, Arkansas
http://jeffsradios.weebly.com
Jeff,
I'll check my notes for the 16X restoration to see if they are appropriate for the tone control.
The big filter can - one can use film caps at 630 V. I'll check my paperwork for the pin connections. Letters through A, B, C, D, E if I recall correctly. One of the 6 terminals has no internal connection.
Regards,
Ed
I'm working on rebuilding the black Bakelite tubs. I have an anomaly. Cap #52 on the paperwork indicates a 7296G here, which is a dual with .05 and a .002 installed.
Instead, in the chassis is a 3903AH installed, which is a single .01. I can find no documentation that mentions this change, but it is a factory install as near as I can tell. My instinct tells me to go ahead and leave this block in place, and just recap it with a new .01.
Is this a mistake in the paperwork, or do I have the wrong paperwork for this run?
Following is the list, schematic and under chassis diagram papers I am working from.
Comments?
[Image: https://farm1.staticflickr.com/925/42980...bd95_z.jpg]
[Image: https://farm1.staticflickr.com/926/42980...85ea_z.jpg]
[Image: https://farm2.staticflickr.com/1761/4298...bd13_z.jpg]
Blessings,
Jeff W.
Jonesboro, Arkansas
Hi Jeff, Sorry I haven't had time to look. I'll consult my notes again. At the bottom of the service sheet, there is a note about changes to certain Bakelite caps including a 7296G, but I cannot read the associated chassis part numbers on this web page.
My chassis is an early 16X, 5 band, so things might be different. I will look it up tonight. I also have notes from the rebuild, and there were differences in the block caps from the part numbers shown in my service data.
Ed
I ran into that on the 38-1 and a couple other radios a time or two. The parts list was different than what the schematics showed and it could have been a change during mid-run, or an error on schematics, etc... but most anomalies like this seemed to involve line filters and 1,000 volt caps.
(06-26-2018, 08:51 PM)EdHolland Wrote:  Hi Jeff, Sorry I haven't had time to look. I'll consult my notes again. At the bottom of the service sheet, there is a note about changes to certain Bakelite caps including a 7296G, but I cannot read the associated chassis part numbers on this web page.
Ed
Ed,
I was browsing through docs I have downloaded pertaining to Philco, and found a PDF compiling Service bulletins of changes made that mention some of the anomalies I've run into Icon_thumbup . The only thing I still need is the pin diagram of the big block can capacitor. Icon_wink
Thanks for your time and help.
Blessings,
Jeff W.
Jonesboro, Arkansas
Hi Jeff,
It looks like you need Philco Service Bulletin 165B. Icon_biggrin
(06-27-2018, 04:54 PM)Nathan Slingerland Wrote:  Hi Jeff,
Nathan,
Thank you so much! Icon_thumbup
Exactly what I needed!
Blessings,
Jeff W.
Jonesboro, Arkansas
This is coming along nicely. All the bakelite blocks are done, electrolytics are done, but still need to finish hooking up, and the large multi-cap can is recapped and hooked back up.  Icon_thumbup
While I'm on this, the owner wanted to look into adding a jack for plugging in an external audio source. I have a 1/8" cut-off jack to install. Would I interrupt the connection at the 5K (R56) Resistor, or on the other side, at the .01 (C57) cap?
Schematic marked for reference:
[Image: https://farm1.staticflickr.com/847/42776...fe6f_k.jpg]
Blessings,
Jeff W.
Jonesboro, Arkansas
Break it at the top of the volume control right next to the #55.
Now I think I've got it!
I couldn't get the connection to work properly, so Scott opted to leave it original. Icon_thumbup
Thanks for the tip anyway.
I did the alignment last night, and it is on it's way home now, reinstalled back in its cabinet. Icon_thumbup
Blessings,
Jeff W.
Jonesboro, Arkansas
There are currently 2128 online users. [Complete List]
» 1 Member(s) | 2127 Guest(s)
