Philco 45C tone control caps?
Im sure this has been asked many times before but what are the values of the caps in the tone control pot of a Philco 45C? I just did a 16B and they where three .003mfd... I have read they where .01, .02, and .001, others have said .01, .02, .003. Any ideas? Thanks!!!
Left to right: .01 uF, .02 uF, .003 uF
The caps in the 45 are used to lessen the high frequency response to the amp. Values are not particularly critical just the larger the capacitance the less high frequency response. I generally error towards the smaller values. Make the sound brighter rather that muffled. The 45 also has what is called loudness control (it done via the tap on the volume control) which lessens the bass response has the volume is increased.
The Philco part number for the tone control is 30-4178, the same as used in Model 29.
The Model 29 schematic gives the values of the three individual caps; the 45 schematic does not.
Model 29:
https://philcoradio.com/library/download...l.%201.pdf
Model 45:
#41 decouples the audio signal from getting into the high voltage. It has nothing to do w/the tone control circuit however #42 (switch and 43 caps) are the tone control.
None of the tabletop Philcos' tone controls work terribly great. Especially if done using correct values.
(41) is not the tone control. Please re-read Terry's post (#6, above).
The tone control is at the far upper right of the schematic, parts (42) and (43).
Yesterday checked Mouser for the price on some caps and was curious about the mica equivalent. The 27pf 1kv ceramic is 2...RodB — 09:58 AM
In some cases the old paper caps can be replaced with ceramic caps, with values such as .001 uf, .005 uf, .01 uf, and ma...Arran — 06:50 PM
Vlad; I would tend to agree, I only suggested the loop antenna connections since he was already looking at the end of...Arran — 06:18 PM
Rod thank you for helping to understand the paper caps and offering the bumblebee caps. I have already ordered film caps...osanders0311 — 03:55 PM
Bob, this is the wrong sequence to look for problems and setup circuits. Always start checking the signal path from the...Vlad95 — 12:19 PM
Philco J1720 stereo and record player with reverb
The above link takes you to the Delaware Valley Historic Radio club. They are not too far from you and may have sugg...klondike98 — 11:49 AM
Tucker Movie Prop car
Richard: Did you ever check with your friend? About once a year I try to verify if Mr Rhoades really worked on the r...WrenchMonkey — 09:22 AM
>>when turning the knobs This is very broad. There are knobs for tuning and knobs for volume, and possibly f...morzh — 07:36 AM
Thx Arran, I will check the antenna connections. Right now the loop is alligator clip connected to the chassis since you...klondike98 — 03:58 AM
Bob; I was just thinking that maybe the 1R5 tube doesn't like being operated at 1.2 volts on the filament, though you...Arran — 12:56 AM
There are currently 1190 online users. [Complete List]
» 2 Member(s) | 1188 Guest(s)
