Philco chassis idenification. 65?, 87? ???
From what i gathered I got a Philco 65 low boy [Late] cabinet, but the chassis diagram dont match up according to the wiring diagram.
I bought the missing tubes based on what a 65 needed.. i have 2 unoccupied tube sockets. the tubes in the pics are a 224, 227, 227.
the 224 has the top hook up, and the 227's are either side of the transformer. that's what it came with. according to radiomuseum an 87 doesn't use 224 tubes. (26 26 26 27 26 45 45 80)
I may have a swapped chassis and be on the wrong track for the tubes. Icon_crazy
I'm use to working on modern technology. i'm having a hard time finding the information i need and getting it working.
The only story i have on it is it belongs to my stepdads dad or grampa. i'm trying to get it working as a fathers day gift.
Hi and welcome,
It's a 95 or 96 both are abt the same.
doesn't look like my 96.
https://philcoradio.com/library/download...l.%201.pdf
It's missing the gigantic tube shield.
It's a model 95.
Notice the cylindrical capacitors, and the large format speaker socket - 1929 design. Philco switched to the bakelite block capacitors in mid-1930 when model 96 was introduced; the 96 also used a much smaller speaker socket.
Thanks a lot guys, much appreciated. Sorry the middle picture was a little blurry.
I was starting to think it was a 96 after looking at more schematic photos. but then i seen a 96 chassis picture and it looked a little different.
I also forgot to make sure i was subscribed to my thread.. On most forum sites that's automatic. oops..
i got all the tubes for it. just need to replace the rest of the caps i wasn't sure about. The schematic link Radiorosyln posted helps a ton. thanks!
it helped me understand part 3787-A a lot better too. I didn't want to do anything with those until i was absolutely clear on it.
a reddit post i found talks about replacing carbon resistors. is that necessary?  and all im seeing is wire wound resistors unless they look way different that what im thinking.
In the philco library im seeing a 95 early and 95 later schematic. https://philcoradio.com/library/index.ph...chematics/
I downloaded both im not sure which i have. but there is little difference and I'll probably find out which when i have the time to do a thorough investigation of the wiring.
I just check to see if they are within tolerance (20%).
okay, thanks for the help. I'll get into it this weekend.
i subscribed to receive an email notification of new replies but didn't receive any...
check your spam box, the email notifications from this site always end up in the spam box (that's the way it is with me anyways and I even tried adding the notifications email address to my safe sender list and it still ends up in the spam box, because apparently they use several different notification email addresses, from what I could see because no two notification email addresses are the same).
Need Help to ID this radio 11 tube Philco
If you want a radio that's difficult to work on, get a 37-620. The one side of the chassis is packed pretty tightly and ...Greg — 07:29 PM
Philco 16 is not intimidating at all. Despite being an 11-tuber. 37-116 is indeed intimidating. 16 has good space unde...morzh — 04:11 PM
48-482 rear panel help
Thanks for the responses Gary and Bob. I'm a little surprised that there's no back panel - although I know older Philco'...keithchip — 04:09 PM
Gary is correct, there was not a rear panel on the 48-482. I restored one of those and its a great sounding radio that ...klondike98 — 03:24 PM
A little light positivity in our feed... To nostalgic retro music... With English subtitles My new video on the contin...RadioSvit — 02:14 PM
My Philco 37-116 Restore
Ron and Mike I mentioned a 2 meg resistor not on the schematic. I stumbled on a changes note in Riders that mentioned th...dconant — 12:02 PM
Here you go: Your the code 125Radioroslyn — 11:12 AM
Hi Ron, Thanks for the input. I think I'm going to call it good enough. It does seem weird I can usually dial in othe...dconant — 08:01 AM
Welcome, the radio looks intimating 11 tubes, wish you well.Jimradio — 07:49 AM
Hi Dan, it’s been 10 years since I restored the electronics on my 37-116 so I’m going on some foggy memories. I remember...462ron — 07:37 AM
There are currently 470 online users. [Complete List]
» 2 Member(s) | 468 Guest(s)
