Philco 38-12 Cabinet Strip
So...just figured I'd share what the radio looks like as I received it this week.  Certainly, there's a lot of cabinet work to do, and I'm a little concerned about what might be hidden under all that dark stain, lacquer, etc.  In addition, the dial is merely a photocopy of an actual dial, the pointer needle is incorrect, the knobs are incorrect, and the speaker fabric will likely need to be replaced.
Luckily, I was able to order a repro dial from Radio Daze, but am having trouble locating the correct pointer, knobs, and fabric.  I know this is probably elementary to most of you, so appreciate any recommendations on sources for these parts.
The grille cloth is correct. It looks okay in the photo - is something wrong with it?
Well, it is much dirtier than it appears in the photo, and won't match a fully restored cabinet very well, unless I can find a way to clean it carefully.  Parts of it are very delicate and will likely fall apart when I remove it anyway. Just want to have a decent backup if/when that occurs.
Finally located the correct knobs, so just hoping someone can recommend a source for the fabric and pointer...especially the pointer, as I'm learning that these are as scarce as hen's teeth!
That silver can capacitor is an aluminum electrolytic. You should replace it with an aluminum electrolytic with the valu...RodB — 11:46 PM
There are currently 1603 online users. [Complete List]
» 1 Member(s) | 1602 Guest(s)
