A learning experience (field Coil)
I just found this.....
https://electronics.stackexchange.com/qu...-from-wire
The bulk wire I use for winding has a single coat that is removed by solder(ing) or just the heat. I think that most of the new magnet wire is that way.
++ on building your own tool (winder).
I saw that at some point. The primary of my transformer is 3200 turns (by hand,neat!)of 38ga wire. I am using Remington wire. 650 turns in, I found a knot. The wire was looped under itself in a knot. I had no choice but to cut it. It was then that I learned to solder 38ga wire. My soldering iron seemed to do the trick, but I would like a better way to get the stuff off the wire.
There is a product out there called "liquid salts". As far as I know it is sodium hydroxide and it has to be heated from a solid to a liquid in order to work. I have some here that I bought to strip the "unstrippable" Litz wire that is found on the market. It works and works well.
https://www.eraser.com/
I melted mine in a little cast iron pot that I used to use for melting lead for musket balls ....
I have some car radio service manuals, Riders I think (not to be confused with the big blue binders), so I may see if on...Arran — 01:20 AM
Philco model 40-100
Greetings; Here is an update, I found a listing on fleabay for a similar chassis to yours, and it has a photo of what...Arran — 12:58 AM
Philco model 40-100
Greetings; I think I may have found a clue as to what is missing, from a search I made, there is a rear view of the c...Arran — 12:12 AM
Philco model 40-100
I recently acquired a Philco model 40-100 farm (battery) radio. The radio was in very good condition except the red on f...mhamby — 05:59 PM
Hello, Richard the radio is an AC-2687 Studebaker model. The Philco model is S -5323 and the chassis p/n is S-5523Pdouglaski — 11:52 AM
48-482 rear panel help
The 48-482 is an AC only set as well, featuring a power transformer. While the transformer shouldn’t get “hot”, it is ye...jrblasde — 11:12 AM
I gave a Chrysler/MoPar car radio from 1954, it was made by Philco, and it uses two chassis, one has the power supply an...Arran — 11:06 AM
Hello keithchip. You could make a hardboard back for the set, but make sure you provide plenty of ventilation holes in ...GarySP — 11:04 AM
Welcome to the Phorum, Phil! Lots of friendly help here to assist you along the way! Take care, - GaryGarySP — 10:55 AM
Hi Pdouglasti, Phirst off, welcome to the Philco Phorum, a Phamily Phriendly place phull of phun pholks and all things ...MrFixr55 — 07:37 AM
There are currently 755 online users. [Complete List]
» 2 Member(s) | 753 Guest(s)
